It is currently Mon Aug 04, 2025 4:03 pm
 Post subject: is my subframe CROOK.
PostPosted: Mon Apr 03, 2006 7:21 pm
I fitted my rear subframe, and the RH wheel stuck out 1/4" further than my LH wheel.
I droped the subframe and I want to know is there a way you can measure the subframe to see if the frame is straght or if either LH/RH arms are str8. Is there any adjustments that can be caried out with the rear frame?
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Mon Apr 03, 2006 9:18 pm
Minis can vary quite a bit, made worse if car has ever had a hit.
Mine was the other way, the RH wheel was 5mm too far in. I made a 5mm alloy wheel spacer.... 8)
 Post subject: mini
PostPosted: Mon Apr 03, 2006 9:21 pm
that was an option, Or adjustable rear camber, with tow in adjustment.
But is there a way to see if the subframe is straght.
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Mon Apr 03, 2006 9:29 pm
If you drop the subframe out you can check the diagonals.
Or go get it wheel aligned. If one side won't go to toe-in with all the shims removed, It's had a hit.
 Post subject: mini
PostPosted: Mon Apr 03, 2006 9:31 pm
I removed the subframe this afternoon. How do u check the diagonals.
I was going to get a wheel aninment But How do they aline the Rear wheels of a mini? Fill it with shims?
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Mon Apr 03, 2006 9:39 pm
Put a tape measure across the front and rear corners, diagonally. They should be ~ the same if frame is not bent.
There is provision for shims between the outer trailing arm bracket and the subframe where the 2 bolts go in. Adding some will increase toe-OUT, but if all shims are out and there is no toe-IN, you have a problem.
 Post subject: mini
PostPosted: Mon Apr 03, 2006 9:58 pm
The RH does have tow in. But if i packed that out with shims, I would get the car to handle well, But that wont fix one wheel being 1/4" further out RIGHT?
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Mon Apr 03, 2006 10:28 pm
If you pack the RH mount with shims, YES the RH wheel will move inwards a bit.
Standard toe-in is 1/8" (half each side, or it'll crab...) :wink:
 Post subject: mini
PostPosted: Mon Apr 03, 2006 10:44 pm
Could it just be the trailing arm?
Is there a way to find out if they are bent?
*Reasonable pricing
*I come to you..
Jay: 0431404607
 Post subject: Re: mini
PostPosted: Mon Apr 03, 2006 11:04 pm
yeah, make sure the subframe is straight - if the subframe is straight then it must be the trailing arm ;)
sorry....
the early SP #64 manual (the one with the engine on the front) has subframe dimensions in the 'body' section
 Post subject: mini
PostPosted: Mon Apr 03, 2006 11:47 pm
I will have to look in my old manuals, Not sure if i have the one with the engine on the front. Should be in all the books. Unless anyone knows it off hand.
*Reasonable pricing
*I come to you..
Jay: 0431404607
Users browsing this forum: No registered users and 111 guests
