It is currently Tue Aug 19, 2025 1:01 am
PostPosted: Wed Apr 12, 2006 3:30 pm
Are sure all four are firing? Are they all reseated properly? What did you use to clean the leads connectors?
PostPosted: Wed Apr 12, 2006 3:36 pm
Push the silicone rubber "boots" back on both ends of the leads,
then fit the leads - you can see that you've pushed them in properly then.
Then slide the boots back down. I'll bet you've just got one lead not pushed home.
PostPosted: Wed Apr 12, 2006 3:41 pm
bez wrote:
ok so in light of this new information, i decided to clean out my points.
firstly i noted that all the points had this white powedered residue stuff which wat is supposed to be cleaned i guess, but out of the four points one was as clean as a whistle and the other four were dirty..... any ideas?
secondly i reatached them all and started him up and the engine is rumbling alot more than usual and as i accelerate it seems like it will stall...any ideas?
need to clarify some terminology here...
distributor points are where the thin wires go to from the coil, when you take the distributor cap off they are in the distributor, there is a red plastic part that is pushed up against the squarish shaft coming out of the motor - the red plastic thing is part of the "contact breaker set" or "points"
the 'points' you cleaned are the distributor cap contacts, and yeah, they're often covered in corroded white crap where the spark constantly jumping through them breaks down the metal...
it sounds very much like you have a poor connection with one of the spark plug leads. Just check each one while the engine is running by firmly grabbing the lead where it connects to the spark plug and pull it off - you might get a bit of a shock through your arm, but you'll get used to it after a little while. The one(s) that don't have any effect on how the motor is running are the ones that are causing trouble - check they're connected to the distributor cap properly - you might have just bumped one off, if you took them all off the cap when you cleaned the contacts, then check you have them in the right order 1-3-4-2, but I doubt you've done that...
PostPosted: Wed Apr 12, 2006 4:05 pm
will do
thanks heaps
a girlfriend would be cheaper
PostPosted: Wed Apr 12, 2006 4:10 pm
Going anti-clockwise
Roads need more corners
PostPosted: Wed Apr 12, 2006 4:16 pm
good point - used to get me all the time....
PostPosted: Thu Apr 13, 2006 11:29 am
i replaced the wires to the distributor cap the same as i pulled them off, but just to make sure how does the 1-3-4-2 concept work? so then i can test if all four are firing properly
PostPosted: Thu Apr 13, 2006 11:53 am
OK, standing at the front of the car looking at the distibutor:
- the lead at about 1 (or 2) o'clock position goes to the #1 cylinder
(the cylinder closest to the radiator)
- the next lead (anticlockwise) goes to #3 cylinder
- next lead after that goes to #4 cylinder
- next lead after that goes to #2 cylinder
but if you took them off 1 at a time, you can't have mixed them up & most likely it wouldn't even run. You probably just have one lead that is not connected properly or is damaged.
PostPosted: Thu Apr 13, 2006 12:08 pm
Gets a little difficult but here goes...
1. First you need to find TDC Top Dead Centre on no 1 cylinder (closest to the radiator) on the compression stroke this will be when both valves are close (rockers are raised).
2. this is around about when no 1 cylinder should be firing, take your distributor cap off and note which contact and lead the rotor button is pointing to it should be pointing to the lead going to no 1 cylinder. If not then change it so it does but make sure you have no 1 cylinder on the compression stroke (both valves closed rockers up).
3 From here it is easy the dristributor rotates anti clockwise so the next lead anti clockwise should go to no 3 spark plug the next one after that is goes to no 4 and finaly the last one goes to no 2.
PostPosted: Thu Apr 13, 2006 12:12 pm
Provided to dizzy drive dog is not out by 180 degrees.... Am I being difficult :lol:
And by finding top dead centre you can get the timing close enough staticly that you will be able to start it and after that you can time it using a timing light. :wink:
PostPosted: Thu Apr 13, 2006 2:10 pm
ok so i ended up removing the grill so i could see distributor properly, all the leads were fine , but i did remove the rubber boots so that i could put them in properly so its working fine now.
although i unplug all the leads one by one, and all four affected the way it was running, so im stumped to know why that connection point from the lead is so clean
PostPosted: Thu Apr 13, 2006 2:11 pm
ohh tand thanks heaps u guys for the help, the only things i know how to do are the ones ive fixed so thats another one to the list!
thanks
PostPosted: Fri Apr 14, 2006 8:51 am
if all for leads when pulled off affected tyhe running, then you should be working properly!
hope you are running well now, remember to check the points gap as well as the plug gap. t check a manual for your particular model, but for me, points gap is 0.015 inch (i think???) and plug gap is 0.025 inch
78 Leyland Mini - Prince
Users browsing this forum: No registered users and 351 guests
