bez wrote:
ok so in light of this new information, i decided to clean out my points.
firstly i noted that all the points had this white powedered residue stuff which wat is supposed to be cleaned i guess, but out of the four points one was as clean as a whistle and the other four were dirty..... any ideas?
secondly i reatached them all and started him up and the engine is rumbling alot more than usual and as i accelerate it seems like it will stall...any ideas?
need to clarify some terminology here...
distributor points are where the thin wires go to from the coil, when you take the distributor cap off they are in the distributor, there is a red plastic part that is pushed up against the squarish shaft coming out of the motor - the red plastic thing is part of the "contact breaker set" or "points"
the 'points' you cleaned are the distributor cap contacts, and yeah, they're often covered in corroded white crap where the spark constantly jumping through them breaks down the metal...
it sounds very much like you have a poor connection with one of the spark plug leads. Just check each one while the engine is running by firmly grabbing the lead where it connects to the spark plug and pull it off - you might get a bit of a shock through your arm, but you'll get used to it after a little while. The one(s) that don't have any effect on how the motor is running are the ones that are causing trouble - check they're connected to the distributor cap properly - you might have just bumped one off, if you took them all off the cap when you cleaned the contacts, then check you have them in the right order 1-3-4-2, but I doubt you've done that...
did I tell you that I won a
trophy?
