It is currently Wed Aug 20, 2025 4:23 am
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Apr 13, 2006 8:18 pm
Bromley wrote:
One other question. Can you put an 1100 crank in the 1275? TK mentions it in his for sale thread.
a 998 or 1100 crank will not fit in a 1275. The latter has 2" mains, the 1100 has 1.75" mains.
The only 1100 that has 2" mains is the later A/H Sprite, but it's a north south crank.
"One other question. Can you put an 1100 crank in the 1275? TK mentions it in his for sale thread."
No I don't
Maybe your getting confused with my South African 1100 crank that is for sale? That will fit a 1275.
PostPosted: Thu Apr 13, 2006 8:22 pm
Do the Morris 1300 (1100S), run the same gear changing mechanism as a mini? I guess the diff is different for bigger wheels and presume the remote/rod mechanism is different as well.
PostPosted: Thu Apr 13, 2006 8:31 pm
1100 all the way maaate 8) ...stuff the 1275...everyone has one of them :P
in regard to 998/1098's struggling up hills...HAHAHAHAHA!!!! My totally stock 998 LOVES hills...I was amazed at first, but I can climb a winding hill in 3rd easily! I drive one particularly steep, hilly road every day, and never feel inadequate :P
Website: www.justanothermini.com
PostPosted: Thu Apr 13, 2006 8:33 pm
Umm
The 1100s runs a slightly different remote change - its different in that it runs a sandwich plate btween the remote and the gearbox. The mini K, deluxe etc didn't run that plate, but they all can be made to fit.
The morris 1300 is a later model and although I am not sure, I think it has a rod change mechanism.
Doc ?????
However, just about all motor models can be made to bolt to all gearbox types. Most just simply bolt up.
PostPosted: Thu Apr 13, 2006 8:34 pm
Yes and no.
It's a remote shift, but there is a rubber sandwich plate between the remote and diff housing. This is to ensure the shift is as imprecise and rubbery as possible.:) :lol:
You can get a steel sandwich plate from MiniMania site, or, swap to a Mini remote and diff housing.
Also, these are only 3 synchro boxes, not 4 synchro.
PostPosted: Thu Apr 13, 2006 8:37 pm
Morris 1300 were all autos, they came out same time as the largely unlamented Morris 1500 5 speed manual. Which had an early cable linkage... :x
PostPosted: Thu Apr 13, 2006 8:38 pm
But Anton, Lillee's 1098 is not just "adequate" she accelerates up hills! :wink: I drive the back streets of Lane Cove to work twice a week and there are some very steep hills there, no problems at all! other cars have trouble :lol:
I too asked this question about 1275 or 1100 build, I decided on the 1275 build. But secretly, I really do like my 1100 and don't plan on selling it. On the contrary, keep it as a spare for that immaculate mini K rebuild later in life (including this rocket prepelled GR 12G295 head) :wink:
Lillee - 1969 Morris Mini K
PostPosted: Thu Apr 13, 2006 8:44 pm
for a 998 or 1100 to make the same power as a standard 1275, it really needs to be a screamer, and the build is going to cost more than to build a standard 1275.... so if you want to spend the $$ to build a screamer, wait for a 1275 and make that scream - easy
put it this way too - my S was running like crap at the dyno day in sydney last year, first run it wouldn't go over 4500rpm, and was just below the top 1100 on hp, I fixed the plug and points gap and then pulled 5hp more that the top 1100 - the motor is now sitting under the bench waiting for a rebuild cos it's out of compression and oil pressure, as it was when it was on the dyno
point made... ;)
Hi - 1275 are the ultimate prospect :P
nothing has changed - money spent for performance gained is far better and will give you at the end more satisfaction.
Don't get me wrong - small bore motors can achieve great results however compared to a 1275 it is really academic as the 1275 output is easily tapped into
Greig...
PostPosted: Thu Apr 13, 2006 8:46 pm
Welcome Aboard Greig.
PostPosted: Thu Apr 13, 2006 8:48 pm
GR also told me that the 12g head is just too big for any small bore. His words not mine, I know a lot of people are doing it.
If I have not found the right 1275 by the time I finish all the body work (hopefully have a lot more done after this long weekend) I will probably continue with the 1100 rebuild. I can alway put it in Bromley later in life.
Wait out for my future threads on gearboxes etc :D
PostPosted: Thu Apr 13, 2006 8:53 pm
Can someone please sell my van hihihi :lol:
PostPosted: Thu Apr 13, 2006 9:03 pm
Yes - welcome Greig
An interesting group
PostPosted: Thu Apr 13, 2006 9:07 pm
Hmmm... having owned a 1220 years ago with Imp pistons, a 544 cam, twin HS4s and a 12G940, all I can say is it went, like shite off a shovel. 8)
Users browsing this forum: No registered users and 373 guests
