It is currently Wed Jul 23, 2025 5:42 pm
 Post subject: Valve Saver?
PostPosted: Sun Apr 23, 2006 4:39 pm
I run 1ml Valve Saver per Litre of fuel (95ron all I can get here).eg. 20litres = 20ml
Now I have a modded motor, cam, head etc....I been told I should double the dose.
What do others use?
Should I be adding more to protect my Valves?
Mike
Lucy - 64 cooper s replica
Lulu - 66 deluxe
PostPosted: Sun Apr 23, 2006 4:47 pm
Keep it at 1 ml per litre. More will just gum everything up. I use flashlube at 1ml per litre.
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Sun Apr 23, 2006 4:50 pm
I run the 1mL/Litre of Flashlube valve saver in my 1360,
When I stripped it last (valves & seats had done 30,000 miles) they were fine- all clean and no valve seat recession. I reckon the standard amount is OK.
If you run NONE after rebuild, I'd give the seats 6 months before needing recutting- I proved this (just for fun) with my son's 1100 Clubby.
PostPosted: Sun Apr 23, 2006 5:58 pm
i thought when you had a rebuild you have a un-leaded head put on and no longer use valve saver.? like every other car. or atleast if you ahve an unleaded head put on.?
PostPosted: Sun Apr 23, 2006 7:25 pm
My 1360 is pretty well ported out, it had oversize (31mm) exhaust valves fitted when done up years ago- no ROOM there for unleaded inserts... 8)
Fitting inserts is an option, I shrink fitted Rover ones to our 1293 when I did it- but that head is near stock. It runs 95 octane and NO additive.
Wife's car... :wink:
PostPosted: Sun Apr 23, 2006 8:46 pm
Well when fitting the oversize valves to the head I was told the converting to unleaded was very difficult to do.
Lulu - 66 deluxe
PostPosted: Sun Apr 23, 2006 9:00 pm
use the stuff, cant hurt can it
also stops pinging
Inconspicuously Conspicuous
Users browsing this forum: Bing [Bot] and 83 guests
