It is currently Thu Jul 31, 2025 6:06 am
 Post subject: Suction or Gravity fed
PostPosted: Sun Apr 23, 2006 10:42 pm
Die Die Die!!
ok its come to the shell work.. for people who can answer this question.. should i get Gravity fed or Suction Fed Spray guns.... or one for basecoat and one for topcoat ?
PostPosted: Sun Apr 23, 2006 11:30 pm
I think a sunction gun is OK for baswork, but would definetly recommend a gravity gun for top coat.
PostPosted: Sun Apr 23, 2006 11:39 pm
What difference do you notice when using the top feed?
PostPosted: Sun Apr 23, 2006 11:43 pm
Its not so much finish, although you can generally get a better flow, rather the gun can be moved a greater angle from vertical when spraying. This means you can spray more easily into this awkward places.
This may help
http://www.autobodypro.com/tektips/articles/spray_guns.htm
PostPosted: Mon Apr 24, 2006 11:51 am
yeah I would buy a gravity feed, star guns have the reputation (and the price to go with it) for my car I used a Fragram gravity feed (about $100) was a great deal easier to handle and better control than a suction feed even as an amatuer I could see they were better
and a few conversions:
13B Extend in a 1600
PostPosted: Mon Apr 24, 2006 1:07 pm
A gravity feed HVLP with a pressure regulator on the handle. Works well for me, but I'm no expert painter. :)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Mon Apr 24, 2006 1:34 pm
Die Die Die!!
cheers for the help people... im looking on ebay now.. i really have a lot to spend on gear.. but i was gonna get one for primer and basecoat.. and one for topcoat...
PostPosted: Mon Apr 24, 2006 3:12 pm
Don't be silly. You don't need separate guns. Your technique as a beginner will affect the quality of the job far more than the gear.
Did you read the article posted?
Even with the spray equipment and the optimum gun settings, a technician's technique can ruin a paint job. "[An] improper spraying technique will result in uneven coatings, mottling, runs and orange peel,"
PostPosted: Mon Apr 24, 2006 7:05 pm
Die Die Die!!
im reading it now... didnt have the time earlier
PostPosted: Mon Apr 24, 2006 7:20 pm
Die Die Die!!
alright i rekon ill get a HVLP gun
something like this..
http://cgi.ebay.com.au/Gravity-Feed-Spray-Gun-HVLP-1-4mm-Plastic-Pot-NEW_W0QQitemZ4545251634QQcategoryZ32053QQrdZ1QQcmdZViewItem
http://cgi.ebay.com.au/AUTOMOTIVE-GRAVITY-SPRAY-GUN-S980-PAINT-CAR-1-4MM-2-PAC_W0QQitemZ4631247222QQcategoryZ43807QQrdZ1QQcmdZViewItem
http://cgi.ebay.com.au/Professional-HVLP-Gravity-Feed-Spray-Gun_W0QQitemZ4457722539QQcategoryZ22779QQrdZ1QQcmdZViewItem
PostPosted: Mon Apr 24, 2006 7:47 pm
Repco - Scorpion brand are OK (same prices, no delivery charges)
