It is currently Wed Aug 13, 2025 6:51 am
 Post subject: sanding paper ?
PostPosted: Tue Apr 25, 2006 6:06 pm
Die Die Die!!
ok im a novice.. and need to finish sanding my car.. 250 grade wet ?.. or wat ?
PostPosted: Tue Apr 25, 2006 6:12 pm
Are you sanding finish coat?
320, then 400, then 1200
PostPosted: Tue Apr 25, 2006 6:16 pm
Die Die Die!!
sanding to bare metal... its alread halfway there on the outside...
PostPosted: Tue Apr 25, 2006 6:24 pm
I never use sandpaper to take a shell back to metal.
I use a wirebrush on an angle grinder. It leaves less marks on the surface.
$25 for the wire brush fitting, $20 for angle grinder. A cheapy from Kmart is fine for the grinder. When its breaks, they swap it for a new one.
PostPosted: Tue Apr 25, 2006 7:10 pm
IMHO I wouldn't bother asking those type of questions here.
If you are REALLY serious about knowing the answer(s), ask the questions here:
http://autobody101.com/forums/index.php
and do yourself a favor and download this:
http://autobody101.com/download.php
That is the freakin BIBLE for body work!
Website: www.justanothermini.com
PostPosted: Wed Apr 26, 2006 12:29 am
Die Die Die!!
rotissery guide is kewl... but the shel prep doesnt really mention anything bout sanding paper grades and sugestions...
Users browsing this forum: timmy201 and 248 guests
