It is currently Tue Jul 22, 2025 1:55 am
Should I keep the extractors?
Yes 86%  86%  [ 19 ]
No 14%  14%  [ 3 ]
Total votes : 22
PostPosted: Sat May 06, 2006 10:49 pm
Hello guys,
I need some advice. Beefa has extractors on him and Ive been told that one side of the manifold has to be cut to put them on...which would explain the flat spot issue with the 1.25' carby (which apparentl hes supposed to have 1.5').
Should I keep the extratcors or give them to hubby and swap him for the normal manifold?
If I swap will there be a loss in power or fuel economy?
Will I lose the nice ass note that my exhaust system has?
Thanks,
Lynda
1978 Leyland Mini 998LS All Original *Sally*
2002 Mini Cooper *Coopa*
PostPosted: Sat May 06, 2006 11:57 pm
By 'one side of the manifold has to be cut' I'm assuming you're refering to the inlet manifold not the exhaust manifold (the extractors).. What inlet manifold are you fitting? I've had twin SU's on mine with extractors and now a dellorto with extractors.. Both the SU and the dellorto manifold needed a bit of cutting and shaving in the area around the head studs to fit, nothing major..
If it's the same for you, just a little trimming, then I'd keep the extractors. They give you more power, not too sure about fuel economy.
PostPosted: Sun May 07, 2006 12:57 am
Did a proper "mini specialist" give you this opinion????
PostPosted: Sun May 07, 2006 9:53 am
I voted yes to keep te extractors...and yep what sort of extractors and inlet manifold are you using and how much modification and who told you..
Pic's will be handy for us to give a comment :wink:
PostPosted: Sun May 07, 2006 10:12 am
The guy at Minisrus told me. He reckons my car should have a water heated manifold and get rid of the extractors becuase thats why I have the flat spot.
I dunno what extractors and inlet manifold Im running, it was on the car when I brought him.
I will take some pics as soon as I can (its pissing down rain here and I dont fancy laying on the ground to jack him up!)
PostPosted: Sun May 07, 2006 10:16 am
If you were in the UK i would say you would need a water heated Manifold, Even with the Melbourne weather you don't need one, I think he is just tryig to sell you something you don;t need
PostPosted: Sun May 07, 2006 10:21 am
I hate it when people try to do that....just cause I'm female :evil:
He reckons I need to buy one off Minisport or one of those guys on Ebay.
PostPosted: Sun May 07, 2006 9:59 pm
At this point, i would personally assume that the fuel needle is incorrect (and possibly the ignition timing too). It is most likely that the current extractors and manifold were fitted but the car wasn't re-tuned to suit them.
Thats just MY opinion of course......
PostPosted: Sun May 07, 2006 10:09 pm
Change mechanic.
Upgrade to a 1.5" carbie.
Keep extractors.
Get car tuned.
Just my thoughts.
No more Minis!......For now.
 Post subject: Yep
PostPosted: Sun May 07, 2006 10:18 pm
Maxi23 wrote:
Change mechanic.
Keep extractors.
Get car tuned.
Just my thoughts.
What he said ^^^^ :)
PostPosted: Mon May 08, 2006 12:20 pm
Does anyone have a 1.5' carby they wanna sell thats in good nick?
Do I need a new manifold as well then? I dont want a dodgy manifold on my car!
PostPosted: Mon May 08, 2006 12:24 pm
You will need a new inlet manifold if you change from 1.25" HS2 to a 1.5" HS4. Just get a late Clubman manifold and chop the exhaust part off so you can use it with your extractors.
PostPosted: Mon May 08, 2006 12:25 pm
Sorry guys but whats the difference between HS2 and HS4?
PostPosted: Mon May 08, 2006 12:31 pm
Stupid HS numbering system:
HS2: 1" + 2/8" = 1.25"
HS4: 1" + 4/8" = 1.5"
Note: the bolt pattern is different, so you must use the larger manifold
PostPosted: Mon May 08, 2006 5:26 pm
Would the extractors give the car serious flat spots (besides the fact that I've probably got a f**ked carby :evil: )?
