It is currently Tue Aug 05, 2025 4:27 am
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Thu May 18, 2006 7:16 pm
I haven't nutted it out yet, but if the cam went round 180 degrees the wouldn't that work?
Or is it that a 'mirrored' cam would be needed? :?
Crap, this will keep me thinking for a while.
:D
Andy wrote:
So you want basically this, with big wheels :lol:
Not quite , he's talking more like this with less body work and bigger wheels....
PostPosted: Thu May 18, 2006 7:21 pm
:D
I think a mirror image camshaft , otherwise if you turn the standard cam 180 degree's it'll still be the same , remember the cam does one full revolution for every two revolutions of the crankshaft .
PostPosted: Fri May 19, 2006 7:09 am
Thats the stuff! that helps actually cause im looking for designs and stuff but yeh rear wheel drive is a must...for me anyways. i think i get what your saying with the rods. now....need a mini shell!
thanks guys
Ed
:) Eddy :)
PostPosted: Sun May 28, 2006 1:44 pm
I had a closer look at the remains of the linkage that came with the fang , I'd only seen one end of it poking out of a box and thought it looked rough . After taking it out I still see it's rough but is so simple in design I'll make a new one . This will work best if the gear shifter is mounted at the same height as the rod coming out of the back of the gearbox . There is no need to change or adjust anything else as the movement on the rod is identical to if it was being operated from behind . Just make sure you have some form of bash guard over the gear linkage though or bottoming out on it might do some damage inside . Hope it helps .
Users browsing this forum: ClubmanGT and 99 guests
