Jim bob , the important thing here is that when pressed up hard against the syncro surface of the gear (the tapered part) as long as there`s something like more than 35-40 thou (ish) gap from the edge of the syncro ring & the side face of the gear, then all should be well
25 tho is just way too little & is a sign that it`s life is nearly over
test each syncro ring onto each gear (mix & match) & just use a feeler gauge to measure them all
make sure when you press them against eachother (the syncros & the gears) that they`re quite flat & not cocked & easy to make sure with the feeler gauge all the way round.
got it???
the 3 sticky outy things on the syncro rings should have a nice sharpish leading edge but it`s not the important part really, more important that you get as much clearance as possible between the synco rings & the gears, that`s what gives you the life factor
have fun man & your 127thou "SMALL BORE" primary gear thrust washer is travelling down to you as i type
