It is currently Mon Aug 04, 2025 11:20 pm
Post new topic Reply to topic  [ 81 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Tue May 23, 2006 6:16 am
how good do you want the finnish?
if you wnt easy, spray it with enamal, really really easy to spray...(hides behind a door and awaits abuse :roll: )
but seriously, its so, so easy to spray, no need to mess arround with clear, and once its on, its on.
(peeks arround edge of door)
yes, it has its downsides too!
PostPosted: Tue May 23, 2006 6:59 am
Here is my effort. Acrylic WRX blue Pearl and white.
I love it - 8)
68 Mini
70 Moke
PostPosted: Tue May 23, 2006 8:35 am
What do you use to mask off parts of the car when you are using different colored paints on the car?
like when using white on the roof and blue on the car, which color do you paint first, how long do oyu wait before you do the next color, nd what do you use the mask off the sections of the car you dont want the second color to go onto?
1975 Hairy Lime/White Clubby
PostPosted: Tue May 23, 2006 8:45 am
High heel ninja
Don't forget acrylic does'nt come shiny off the gun, it has to be rubbed down & buffed to get a deep finish in it, its very easy to burn the paint whislt buffing it, 666 you seem to think its going to be cheap & easy to get a show quality finish, you are very wrong indeed.
Doogie
PostPosted: Tue May 23, 2006 8:54 am
i did mine with acrylic, it was first painted black then had 4 coats of blue/purple pearl (of my own receipe) clear coat, then another 4 coats of straight clear, only did this coz it was free and i had all the spray gear at my work, still gotta cut back a few (read most) of the panels still
PostPosted: Tue May 23, 2006 9:54 am
im with doogie on this one,
acrylic paint isint easy to get a good finish with, i sprayed an austin 1300 over summer and its fairly average, im assuming you are painting this one black still? black paint is literally the king of darkness (the father of mr lucas and Mr Brian Warner (im sure you know who i mean)) apart from showing up every little scratch and dent that hasent been taken out, everytime you point the gun the wrong way, or hold a little long, BAM, it smacks you in the face. not freindly stuff. :evil: especially dificult on large panels such as the roof (easy to get streaks)
ok thats my rant, im about o go buy some white ppg dulon for my alfa bumper..
PostPosted: Tue May 23, 2006 10:34 am
Die Die Die!!
nah its all good.. i dont expect it to be easy as long as its acheiveable...
PostPosted: Tue May 23, 2006 10:37 am
it IS easy... just pay someone to do it...
PostPosted: Tue May 23, 2006 11:04 am
13secmini this might be a stupid question but which do you rekon is a better paint.. and arnt your sposed to have a respirator ect.. for 2pac.. ? hence this thread.. im looking into acrylic after hearing about the cancerous side of things...
I'd still be wearing a respirator with acrylic too... :wink:
PostPosted: Tue May 23, 2006 11:10 am
2pk spay is very bad for you, but so long as ou wear a proper mask you'll be ok..pref get an air fed mask...and also if you dont use a oven when you use 2pk you'll actually get more of a glossy finish....true
wouldnt recomend using black paint because it shows up every crap detail on the car, acrylic paint is fine but as other people have said if you want a gloss finish you'll have to do lots of clear coats.
drying times vary, but acrylic paint can dry in 5 mins in warm weather, 2pk takes ages and thats why people use baking ovens...takes about 2 days to dry normal (non oven)
are you sanding the car back or just going to paint it up?
PostPosted: Tue May 23, 2006 11:34 am
Die Die Die!!
its already half bare metal... but ill be sanding it the whole thing back as its started to develop surface rust.. due to lack of funds..
PostPosted: Tue May 23, 2006 11:37 am
High heel ninja
Spray it with WD 40, will stop surface rust developing.
Doogie
PostPosted: Tue May 23, 2006 11:38 am
Die Die Die!!
how do you get it off when it comes to priming ?
PostPosted: Tue May 23, 2006 11:46 am
Prepsol.
PostPosted: Tue May 23, 2006 11:47 am
High heel ninja
Prepsol
Doogie
