It is currently Sun Aug 03, 2025 6:39 am
 Post subject: SU or Weber or what?
PostPosted: Wed May 24, 2006 9:44 pm
Hi, can anyone tell me what's the better carbie option to maximise mini engine performance? Is it using a weber or an su? What are the benefits, differences or downside of either option? What size su or weber is best?
67 Deluxe under going full resto
PostPosted: Wed May 24, 2006 10:53 pm
It mainly comes down to the size and modifications to the engine. What are your engine's specs?
PostPosted: Wed May 24, 2006 11:13 pm
I don't have a mini at the moment and am looking for knowledge. Hopefuly it will be a 1275
PostPosted: Thu May 25, 2006 3:36 pm
998/1100 stock to medium mods - 1.5" SU
998/1100 high mods (hot cam, hot head, extractors) - 1.5" SU, 1.75" SU or twin 1.25" SU
Standard 1275 - 1.5" SU, 1.75" SU or twin 1.25" SU's
1275 medium mods - 1.75" SU, twin 1.25" SU's
Hot 1275 - 1.75" SU, twin 1.25" SU's, twin 1.5" SU's, 45 Weber
That's a VERY ROUGH guide!
PostPosted: Thu May 25, 2006 5:04 pm
so would having a webber on a presummed stock 1100 have any benefits or is it just a waste?
Cheers James
'75 windowless van
~LOLA~
PostPosted: Thu May 25, 2006 5:31 pm
Sounds nice!
but yeah, a waste of $$$ and fuel. Spend the money on a decent extractors/exhaust :wink:
PostPosted: Thu May 25, 2006 5:47 pm
Cheers James
I had a 40DHLA dell'orto on my stock 1098, it went great and sounded nice. Had I put in a slightly warmer cam, duplex timing chain and maybe a little bit of head work it would have gone very well. Does use a bit more petrol, but on a Dell'orto you can manually adjust the accelerator pump which probably helps. The trick is to have it jetted properly (ie on a dyno), or else likely as not you'll just wash your rings with petrol.
PostPosted: Thu May 25, 2006 5:51 pm
Thanks. Thats great. It a hot 1275 does the usage of a weber over a 1.75" make a big difference if any?
PostPosted: Thu May 25, 2006 5:55 pm
Yeah, but only if it's in a high state of tune. Mate of mine has a hot 1275 (100hp odd I think) and he upgraded from a 1.75" SU to a 45DCOE on a 6" manifold, it made a fair difference. But he's like me, he likes the noise of a weber :)
