Anto,
Usually it's the front bush (nearest motor) that wears. These days a floating bush is available for the 1275 primary gear, I fitted one to Cody's.
It just slips in after the old bush is removed (I just bore them out in the lathe).
The rear bush if worn can be replaced, then it is bored to size in a lathe, not reamed.
PM me if you need one done.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
