It is currently Sat Jul 19, 2025 11:18 am
 Post subject: Change Fuel??
PostPosted: Fri Jun 30, 2006 6:31 pm
pristic wrote:
It may be fuel related though. Maybe the unleaded with no additives doesn't like low temperatures.
Try some sooper dooper fuel then Mike...just a tankful while its cold...what sort of CR do you reckon you have :?:
 Post subject: Re: Change Fuel??
PostPosted: Fri Jun 30, 2006 7:21 pm
I get about 6 weeks out of a tank so winter will be almost gone before I need to fill up again!
Compression ratio = 8.5:1
Compression gauge = 125psi. :lol:
I have not had any problems since I have been parking the car nose in to the carport.(engine away from the cold) 8)
PostPosted: Fri Jun 30, 2006 9:34 pm
Well :!: :!: :!: .....there's probably half the problem :!: :!: :!: ...take her for a blast down to Collector or somewheres to blow the cobwebs out :wink: :wink: :wink:
PostPosted: Fri Jun 30, 2006 9:41 pm
And that will stop the needle valve from sticking shut then it is -7?? :lol:
PostPosted: Fri Jun 30, 2006 10:02 pm
ausmini mod
ausmini mod
Sorry when I said "its not the cold" I meant its not cause thhe needle is freezing.... yes, its definately the cold thats the catalyst.
My point was its NOT a starting problem... which is what people were starting to get into.
Any luck with needles?
Have you blown the cobwebs out yet?
Peter.
PostPosted: Fri Jun 30, 2006 11:09 pm
Yes :!: Prolley :!: :!: :lol:
PostPosted: Sat Jul 01, 2006 10:23 am
Bloody SUs...
Prehistoric design- sticky needles, carby icing....
Gimme my 45 Dellorto any day! 8)
Users browsing this forum: No registered users and 69 guests
