It is currently Tue Aug 05, 2025 1:54 pm
 Post subject: Slow Clutch Return
PostPosted: Tue Jul 04, 2006 11:30 pm
Die Die Die!!
when i push my clutch in its harder than usual.. and its slow to return (but still driveable ..just) i was planning on changing the slave cylinder... is this ther right way to go... ? any idea's ?
PostPosted: Wed Jul 05, 2006 12:01 am
Make sure there is no air in the system.
Inspect the hose for any splits or leaks where they go in to the slave or out from the master.
Bleed the clutch.
Then if your problems persist, please see your health care professional.
PostPosted: Wed Jul 05, 2006 12:18 am
Die Die Die!!
lead has a leak just before or at ther slave connection... i know that...
PostPosted: Wed Jul 05, 2006 8:56 am
Replace the hose. Over time they swell internally, restricting flow. This would give you the symptoms you describe. The hose is pretty cheap from a brake 'n' clutch place who probably have them in stock.
PostPosted: Wed Jul 05, 2006 6:23 pm
Die Die Die!!
yep im doing it 2moro... $24 :)
Users browsing this forum: Bing [Bot], drmini in aust and 92 guests
