It is currently Tue Aug 19, 2025 3:41 am
PostPosted: Thu Jul 06, 2006 8:40 pm
Trolling Fleabay and found this - the oil filter looks very different that what I am used to and lots of smaller differences...
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Thu Jul 06, 2006 8:42 pm
WT???? Never seen that before either.
PostPosted: Thu Jul 06, 2006 8:45 pm
Yeah, I have an A+ like that. :wink:
PostPosted: Thu Jul 06, 2006 8:48 pm
What I would give for the oil filter to be that easy but imagine cleaning off the sheet of oil from the motor every time you changed the oil...
Looks good though
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Thu Jul 06, 2006 9:24 pm
Knock a hole in the filter with a screwdriver and let the oil run back into the engine. :wink:
My A+ has a different crank and a different sump.
PostPosted: Thu Jul 06, 2006 9:26 pm
A+ aint it?
PostPosted: Thu Jul 06, 2006 9:37 pm
Late A+, there's no dizzy hole... :wink:
 Post subject: and...
PostPosted: Thu Jul 06, 2006 9:47 pm
Loosen the filter, Knock a hole in the filter with a screwdriver, turn the filter so hole faces down, catch leaking oil in container.....no mess oil change :idea: :D
PostPosted: Thu Jul 06, 2006 9:59 pm
Iwas going to say South African till I saw the oil filter wasn't angled to the block (still the same spot) and there was no dizzy hole . Late model A plus with the little electronic ignition module that runs from signals off the crank .
PostPosted: Fri Jul 07, 2006 6:42 am
single or twin point injection.
welcome to the 21st century guys.
they are not that great being A+ and all.
www.minicranks.com add me to your watch list and come back again soon, under construction.
Users browsing this forum: No registered users and 342 guests
