It is currently Thu Jul 31, 2025 7:52 am
PostPosted: Mon Jul 10, 2006 10:19 am
ausmini mod
ausmini mod
Hi,
If I pull back the carpet, clean it all up, wire brush it, rust convert it, and supply the floor pans... how much would a panel beater charge to weld in the new floor pans? (I need front left and front right)
I dont need him to seal it, i'll seal, paint, etc... just cant weld.
Peter.
PS: Im in Sydney (Hills area of course)
PostPosted: Mon Jul 10, 2006 5:32 pm
I got mine done here for around $100 that included everything at $25/hour.
PostPosted: Mon Jul 10, 2006 6:04 pm
Die Die Die!!
cheapest i got quoted for cut, weld (i supply the pan), and deaden was $300 (max $400) for just the passenger side...
PostPosted: Mon Jul 10, 2006 7:27 pm
ausmini mod
ausmini mod
Awesome!
Thanks for the replies fellas, I appreciate it.
Peter.
PostPosted: Mon Jul 10, 2006 8:32 pm
Don'r `rust convert' it until after welding. MIG doesn't like it...
Trust me, I'm a welder.... :lol:
PostPosted: Mon Jul 10, 2006 9:01 pm
i need the same but have rust converted surley you can just sand back the area to be welded as your cutting most of it out anyways??
the thing i wanna know is - is it bracing really needed to do it what if you do one side at a time still need to brace the body :?:
PostPosted: Mon Jul 10, 2006 9:03 pm
The rust converter is phosphoric acid, it not only stinks when welded but upsets the arc, similar to welding over zinc.
sanding would help, but better not to convert it until welded.
Users browsing this forum: Bing [Bot], lomin and 98 guests
