It is currently Fri Aug 22, 2025 4:18 pm
 Post subject: Mini Coil Spring Kit?
PostPosted: Thu Aug 10, 2006 11:29 pm
Has anyone tried replacing their rubber cones with coil springs?
http://www.minimania.com/web/Item/C%2DS ... Detail.cfm
It doesn't seem like a bad idea but I'm interested to hear everyones thoughts?
Thanks,
Jacks.
PostPosted: Fri Aug 11, 2006 6:17 am
Do a search on here and on minimania.. one of the problems I remember off my head was they can fall out of place.. Generally either people love them or hate them.. I say if you have the money give them a go, if not don't waste your money, rubber cones are already proven. Even just putting in brand new rubber cones, will improve handling if your old ones are a bit worn... so I've heard..
PostPosted: Fri Aug 11, 2006 8:11 am
PM Max23 urgently before you consider the UK stuff!!!!!
I have seen some in the photos taken at Delta Mini that have a second, soft spring to keep the assembly fom falling out. Similar two-spring arrangement to the Eibach setup used in coilover applications.
Also, so a search on here, a lot has been written about those springs.
M
PostPosted: Fri Aug 11, 2006 1:02 pm
M
okay mate, I have pm maxi23 - I did search the forum before posting and I found no discussions at all about these. Maybe I didn't search for the right thing?
jacks.
PostPosted: Fri Aug 11, 2006 1:21 pm
I reckon the discussion was one of those that disappeared when Ausmini went down. Bummer.
Short answer:
These springs can fall out unless some form of droop stop is used, like shocks with shortede extended length. Could try to tie them in...
It is very difficult to make a spring of this geometry accuratley so the spring rate may vary from unit to unit. Depends on quality of manufacture.
Max has found that mini-spares(sport??) springs fail from brand new!
M
PostPosted: Fri Aug 11, 2006 1:41 pm
Short answer:
M
A failure would be bad - I want something ultra reliable. I've got new "rally" rubber cones and they are good but they are very harsh. I need it to be pretty firm as my car us used to road rally / hill climb etc - but I thought the spring might give me better grip levels.
jacks.
PostPosted: Fri Aug 11, 2006 7:35 pm
Main problem with these springs I've heard is that as they are only 1 or 2 coils, they have hardly any spring rate compared to rubber cones. I doubt they would survive rallying..... :wink:
I'd go on MiniMania forum and see which ones (green, red, whatever) people are running.
PostPosted: Fri Aug 11, 2006 8:39 pm
Sorry, I said PM Maxi23 but I SHOULD have said PM Clubmn. Jay (Clubmn) is the one...
Duh, my bad...
Users browsing this forum: jimb and 289 guests
