It is currently Thu Aug 21, 2025 4:17 pm
PostPosted: Fri Aug 11, 2006 6:39 pm
with the oil groove there seems to be 4 peices, two rings the std oil thing that goes between them and this 7 sided thingo ?
the seven sided thingo iv neve seen befor
help how does it go together, ill upload a pic if it dont make any sence
PostPosted: Fri Aug 11, 2006 7:10 pm
On 1100 and 998 Hastings rings, the 7 sided thing is a spring. It goes in first. DON'T LEAVE IT OUT.
Then the centre piece goes in.
Then the 2 oil scraper rings go each side of that. :wink:
Should be instructions in the box....
PostPosted: Fri Aug 11, 2006 7:15 pm
thanks kev , i thought thats how it went beut it just looked wrong, the instructions are terrible :(
PostPosted: Fri Aug 11, 2006 7:19 pm
It's hard to get the oil rings wrong, but watch which way up the compression rings go. Read the instructions... then check the rings, carefully.
Users browsing this forum: No registered users and 322 guests
