It is currently Thu Jul 24, 2025 6:22 am
 Post subject: ball joints
PostPosted: Sun Aug 20, 2006 9:45 pm
hi guys and girls i have just bought all new ball joint for my car i was wondering sould i pre grease them first or should i just fill them by the grease nipple and when filling by the grease nipple how do i know how much to put in.
Cheers Dan
 Post subject: pre packed
PostPosted: Sun Aug 20, 2006 10:52 pm
Well if they have grease nipples....I would have thought they would already have some grease in there already....the nipple is to service regulary....if you want to play safe....squirt a small amount of grease in the nipple and see if you immediately get a discharge :oops: :D
PostPosted: Mon Aug 21, 2006 8:45 am
When torquing up the ball joint to check the shim thickness, this should all be done dry. If you have it greased up you will throw off your shim thickness measurements.
Once all assembled and torqued up, then apply the grease :)
PostPosted: Mon Aug 21, 2006 5:05 pm
so i should put the ball joints in dry then add grease how do i know how much grease to put in
Cheers Dan
PostPosted: Mon Aug 21, 2006 5:40 pm
Fill until it squrts out from the ball joint or the nipple
THERE IS NO SUCH THING AS TO MUCH LUBE......
wipe away the excess after...
Beanie
PostPosted: Mon Aug 21, 2006 5:47 pm
Be careful that it doesn't become hydraulic though - if there is nowhere for the grease to escape then it will get harder and harder to pump grease into the ball-joint until something gives way under the pressure
PostPosted: Tue Aug 22, 2006 6:01 pm
cheers guys for your help
Cheers Dan
Users browsing this forum: Bing [Bot] and 104 guests
