It is currently Mon Jul 28, 2025 5:34 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
PostPosted: Sat Aug 26, 2006 5:40 pm
And I found out it has a blown head gasket and that teh head is split and it was only running on 2 cylinders....
Plus other things, will have to spend $3500 to gte it to a perfect car..........
I am getting the most important things upto a grand fixed, that should make it roadworth for a little.....
Many others have to spend a bit to get there mini upto a good standard?
Ian
Ian - My Ve SSV Ute - Looking for a Mini
PostPosted: Sat Aug 26, 2006 6:09 pm
2 cylinders did your car ever get above 60 kmph
PostPosted: Sat Aug 26, 2006 6:13 pm
yeah it was going about 80kms.... then all of a sudden was running like a dog and this explains why, apparently it has been blown for a while, the remove dtheg head and didn't put it back correctly :(
PostPosted: Sat Aug 26, 2006 6:56 pm
dodgy backyard mechanics :evil:
PostPosted: Sat Aug 26, 2006 6:59 pm
Yeah now I have to pay to get it fixed :(
PostPosted: Sat Aug 26, 2006 9:56 pm
How did you not know it was running on 2 for a while?
As soon as my moke dropped to 3 it shuddered like I was taking off in 4th and was obvious as rain ?
Shard
PostPosted: Sat Aug 26, 2006 10:01 pm
no i think he said it happened suddenly,
no, at that price i would buy a much better mini...
so you can do a 666, and keep buying em and selling em..
i am sure someone on here can help you for far less..
a head and a gasket shouldnt be more than a couple of hundred.
PostPosted: Sat Aug 26, 2006 10:05 pm
Ian
What else does it need apart from the head and gasket ? Head swap is fairly easy to do , just carefully follow the instructions in a manual and take your time , surely someone over there can give you a hand or guidance ?
PostPosted: Sat Aug 26, 2006 10:26 pm
Just be aware that this does not have to cost a fortune.
A head gasket kit is <$30 - a head is bugger all from a wreckers or a mini enthusiast and the how too s are freely availbable in manuals and forums/.
Getting your head done particularly with a crack in it is $300 - 400 any day of the week. A head from a wrecking yard or mini-ist is a lot less
dont spend money unwisely and throw away the enjoyment of being a mini owner. Bathurst for the mini was over long ago.
PostPosted: Sat Aug 26, 2006 10:44 pm
Brakes, Suspension, Radiator.... And then small things...
Is about $360 good for re-cored radiator and head been done?
PostPosted: Sun Aug 27, 2006 10:13 am
[quote="YoungMiniac"]Plus other things, will have to spend $3500 to gte it to a perfect car..........
Ian[/quote]
Ian....do you have an itemised quote for $3500 :?: Is this from a reputable Mini garage :?:
As others have said....you may not have to spend a fortune to get this little jigger running :idea: :lol:
PostPosted: Sun Aug 27, 2006 10:57 am
I got an inspection from Cono at MiniCraft who has been reccommened from this forum....
If you want I coudl scan it and show you all....
PostPosted: Sun Aug 27, 2006 11:06 am
Please do - but bear in mind that we havn't seen the car either. Do you have phots of it as well .
PostPosted: Sun Aug 27, 2006 11:17 am
Pictures here : http://www.ausmini.com/forums/viewtopic.php?t=21643
PostPosted: Sun Aug 27, 2006 11:21 am
Here is what it says
SAFETY CHECK ~ REPORT
REQUIRE ATTENTION
ALL BRAKE DRUMS - 2ND 0/SIZE
REAR BRAKES ON MAX (JUST DRUMS?)
FRONT WHEEL CYLINDERS WEEPING 6 RUSTY
REAR WHEEL BEARINGS DRY
FRONT WHEEL BEARINGS, ALL BALL JOINTS, LOWER & TORSION
ARM BUSES, INNER CV BOOTS
FRONT SUSPENSION LOW (SUSPENSION UNITS & KNUCKLES)
ALL SHOCKIES
STEERING RACK & TIE ROD ENDS
RADIATOR 0/5, LOWER BOLTS MISSING, CORROSION CN WATER
PUMP,
CLUTCH RETURN SPRING MISSING
MID EXHAUST MOUNT
OIL LEAKS - ENGINE BACK PLATES, RIM DIE’? SEAL,
SELECTOR SHAFT SEAL, DISTRIBUTOR 0-RING
ENGINE STEADY BAR BRACKET LOOSE
HEAD GASKET
CLUTCH BEARING NOISY
Will scna images now
