It is currently Sat Jul 19, 2025 2:08 am
Post new topic Reply to topic  [ 63 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: Rod or Remote Change
PostPosted: Tue Aug 29, 2006 7:21 pm
I have a problem...
i dont know what gearbox is in my 72 clubman. i need to find out what box is in it so i can source a replacement for it.
any help would be appreciated.
Ben
PostPosted: Tue Aug 29, 2006 7:22 pm
if you have to lift for reverse its a rod change, otherwise look under the car, if it has two rods its a rod change
if it has a large metal casing, its a remote change.. also remote changes will rattle like all hell :wink:
PostPosted: Tue Aug 29, 2006 7:29 pm
hey spaceboy,
box is much like any gearbox in a conventional car (aka. dont have to lift to put in reverse.) and by large metal casing do you mean at the floor and approx. 10cm diameter?
While we're on the subject I'll add my own unique brand of newbiness to it, which is better, the remote or rod, and why?
PostPosted: Tue Aug 29, 2006 7:30 pm
Why do you say that?
Lillee - 1969 Morris Mini K
PostPosted: Tue Aug 29, 2006 7:32 pm
Correction: Noobiness
PostPosted: Tue Aug 29, 2006 7:33 pm
my remote never rattled :roll: 8)
PostPosted: Tue Aug 29, 2006 7:34 pm
bmx_bandit wrote:
hey spaceboy,
you have to look under the car,
but yeah you can take off your rubber gearlever boot and if you only have to twist and push to take the gearlever out its a rod change, if you need tools to get it apart its a remote change.
rod change is clearly the superior setup, being used on all minis from the 70's on. having no vibration and a lockout for reverse, and easier to install, uninstall, less wear etc.
remote change is better for racing, as it acts like a strong engine steady, and has a more direct feel, most would say a superior feel. :wink:
PostPosted: Tue Aug 29, 2006 7:38 pm
looking like a remote... will check on the two rod theory tomorrow
PostPosted: Tue Aug 29, 2006 7:39 pm
LOL rod change is the cheaper set up thats why they used it from 70's on
PostPosted: Tue Aug 29, 2006 8:00 pm
too true. :wink:
Remote was an engineered solution (by John Cooper, esq),
Rod change was an agricultural solution that helped BL avoid paying him £2 per car royalty... :lol:
PostPosted: Tue Aug 29, 2006 8:01 pm
i'm not buying it
PostPosted: Tue Aug 29, 2006 8:15 pm
its true u can belive it or not
they were all bout savin money thats the leyland motor company :roll:
Myth. :lol:
I doubt it. The remote shift is just an improved version of the Morris 1100 shift. They wouldn't have to pay Cooper for something that they designed themselves. :wink:
John Cooper never engineered anything. I don't think that there were any engineers at Cooper. 8)
PostPosted: Tue Aug 29, 2006 8:26 pm
well still would be cheaper to make i think
