It is currently Fri Jul 18, 2025 9:34 pm
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Sep 09, 2006 7:32 pm
I had my trailer custom built last month, wasn't cheap but was worth every dollar.
1969 Mini 1330cc
PostPosted: Sat Sep 09, 2006 7:42 pm
I used a double axies trailer not long ago and when driving down the freeway I noticed that a lot of the single axies trailers I saw on the motorway being trailered swayed quiet a lot at 100kph. At the time I was doing 120kph-130kph (I know its not the legal speed limit) but the double axies trailer was smooth the whole way.
Roundies Rule !!!
PostPosted: Sat Sep 09, 2006 7:50 pm
K Man,
that looks like a nice trailer. How about a few details/more and bigger pics. Does it have ramps built in etc?
KB
PostPosted: Sat Sep 09, 2006 8:21 pm
The trailer is 1.6m wide internally and the sides are 160mm high so it is easy to get the doors open, the ramps are 2100mm long in steel and slide directly under the the deck. All you need to pull them out is two spring clips and two split pins.
The front rail sits lower in the centre front to allow the sump to clear and the front tyres rest against the raised sections. I also had nuts holes drilled and nuts welded underneath for custom made"tyrebelts" which sit over the tyre and bolt to the deck for both front tyres and one rear so I can tow either the van or sedan. Also got tie down points in all corners with enough space to use ratchet straps if needed.
I chose to go for brand new 13inch perforance alloy wheels with light truck tyres, just to keep the trailer low so the car doesn't bottom out.
1969 Mini 1330cc
PostPosted: Sat Sep 09, 2006 9:38 pm
Does the maker still have the design? Maybe some people might like to have a trailer like yours.
Roundies Rule !!!
PostPosted: Sat Sep 09, 2006 10:47 pm
If it was commercially built, they'd probably be a bit protective of it I suspect - intellectual property and all that. Maybe better for someone to measure it and draw up some plans or take some more photos as well.
I've been toying with building a trailer for some time. After some study, I'm leaning towards a tilt trailer to save on having to carry ramps around.
Still there were some design elements of k man's trailer that looked real nice.
KB
PostPosted: Sat Sep 09, 2006 11:04 pm
Yeh but the people who built his trailer wouldn't want to make more??
Roundies Rule !!!
PostPosted: Sat Sep 09, 2006 11:55 pm
Sorry Gavin - I thought you meant get the plans for other people (ie us) to make his design, rather than the original manufacturer making more for other mini owners. In that case I'm sure he would still have the plans, most of them just work off photos and basic measurements anyhow and customise it according to the customers wishlist.
KB. :)
PostPosted: Sun Sep 10, 2006 7:44 am
Contact Austrailers at Campbeltown, he has the measurements, plan and a photo or go to www.austrailers.com.au
Be prepared to spend over $2500.
Remember if they build it they usually include second hand wheels/tyres so you must be specific.
1969 Mini 1330cc
PostPosted: Sun Sep 10, 2006 12:23 pm
Wow 2500
Roundies Rule !!!
PostPosted: Sun Sep 10, 2006 3:03 pm
High heel ninja
fock me $2500!!!!! I paid $2700 for a brand new 13 x 6 dual axle trailer with electric brakes, i think they saw you coming, try Holiday trailers at Yennora, cheapest in Sydney.
Doogie
PostPosted: Sun Sep 10, 2006 7:55 pm
I got a couple of prices and had already used a few companies for other box and boat trailers however I found these guys to be the best to deal with.
I was happy to pay the cost of having it custom built to exactly how I wanted it which included the disc brakes and brand new alloy wheels, including the spare, thats where the price added up.
1969 Mini 1330cc
PostPosted: Fri Jun 20, 2008 4:04 pm
Can I please bring this thread back from the dead and ask for more photos of peoples Mini trailers! I'm looking to get one built. 8)
PostPosted: Fri Jun 20, 2008 4:20 pm
High heel ninja
Once again heres my trailer, it's been evry where man.
Doogie
PostPosted: Fri Jun 20, 2008 4:28 pm
Cheers mate!
The VR4 too?
