It is currently Thu Jun 26, 2025 5:06 am
 Post subject: 4EFTE alternator wiring
PostPosted: Wed Sep 20, 2006 12:47 pm
Gents,
I need some help. I am have installed the engine harness and extended the wiring for the altenator.
The alternator wiring comprised of 1. the positve feed for charging 2.the round black plug and 3. there is a small plug with one black wire(white tracer) aswell.
I have plugged all except for No.3. I can't find where it was plugged in, i need some photos or someone to check their car please.
I thought that it may have been for the starter motor but it had its own part of the harness with only the main feed.
DAN
PostPosted: Wed Sep 20, 2006 1:20 pm
Dan, the lead to the terminal on the alternator has two leads as it makes a complet circuit that is passed back through a large fuse (fusible link essentially) inside the fuse box. In addition you should have the plug that goes in the back of the alternator. Is this any clearer? I can take a few photos as mine is out of the car at the moment...???
M
PostPosted: Wed Sep 20, 2006 3:01 pm
Matt,
Yeah Photo would be good.
It's the black wire with the white trace on it that i can not find where it goes.
Thanks
Dan
PostPosted: Thu Sep 21, 2006 11:10 pm
I think i figured it out, it plugs into the starter so that is where i have connected it.
Can someone check their starter please.
Dan
PostPosted: Thu Sep 21, 2006 11:24 pm
minimetoy
I just checked my loom and i think you are right. I have a fat black wire with a white trace that came off the starter. Hope this helps.
Madmorrie
PostPosted: Fri Sep 22, 2006 10:41 am
Thats it.
Thanks Madmorrie.
Dan
