It is currently Tue Aug 19, 2025 6:20 am
 Post subject: Brake Rotors.
PostPosted: Fri Sep 22, 2006 6:42 pm
I just got my new rotors for the LS today from eBay and i noticed that there are no studs in them.
Should i get new ones and screw them in or try to get out the old ones???
I think i may need on of those 1/2" sockets with the rollers inside, which i don't have.
Santo
"The Lone Ranger"
HI-HO Silver......AWAAAAAY!
PostPosted: Fri Sep 22, 2006 6:57 pm
Nah, you can use the old ones if you need to, you need to tap, tap, tap them out with a soft mallett.
They are simply held in by a press grip on splines, just tap them backwards through the disc flange. If you get new ones, the disc studs are slightly longer than the standard drum type.
PostPosted: Fri Sep 22, 2006 7:43 pm
hmmmm...I have heard of studs developing hairline cracks from being removed and replaced.
Personally, with new rotors I would DEFINITELY buy new studs.
Up to you though.......
PostPosted: Fri Sep 22, 2006 8:20 pm
Don't the LS brakes have the studs in the drive flanges- not the rotors like S did? :?
I have Josh's new ones here..... the 8.4" drive flanges have the studs.
PostPosted: Fri Sep 22, 2006 8:42 pm
The doc is right, they have the studs in the drive flange and the flange bolts to the disc.
PostPosted: Fri Sep 22, 2006 9:16 pm
aaaaahhhhh....so now I know, are they still held in the same way?
I've always re-used them with no ill affects, although I have broken one or two before. When I pull them back through, I don't whap 'em back in, I pull them through using the wheel nut nice and gentle, maybe this is where hairline cracks develop if you're not kind to them.
PostPosted: Fri Sep 22, 2006 9:34 pm
These have threads tapped in them as per pic....
If the studs are attached to the drive flange then have i bought the wrong rotors?
Santo
"The Lone Ranger"
PostPosted: Fri Sep 22, 2006 9:41 pm
no, you've got the right rotors, those threads are where the drive flange bolts on.... ;)
PostPosted: Sat Sep 23, 2006 7:19 pm
Job Done!
Was a bit of a sh!t getting the hub nut off though...
Santo
"The Lone Ranger"
Users browsing this forum: Majestic-12 [Bot] and 87 guests
