It is currently Sat Jul 19, 2025 2:31 am
Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Fri Oct 29, 2004 1:09 pm
cheers jam....
i'm hoping for as flush to the floor as i can....
PostPosted: Thu Nov 04, 2004 1:44 am
Make sure your replacement button can handle the current draw from your starter..... we dont want to start a fire, do we :wink:
JFTR - SC850 has a master cut off switch at that location. The start button is getting relocated or maybe exchanged for a starter solenoid and morris key start.... A master cut off switch is good for security 8)
PostPosted: Thu Nov 04, 2004 5:40 am
I thought of putting a `red key' master switch where the button is (850 shell), but canned the idea- the switch body is just plastic and would be just above the 2" exhaust.. :shock: melted live battery cable dropped onto the ex pipe is not a good vision.. :cry:
If you want a switch there make sure it's going to stand the heat... :wink:
PostPosted: Thu Nov 04, 2004 10:12 am
thanks for the tips doc.. ;)
i did actually think about a button like they had on sale of the century.... i nice big boombah red one.. ;)
PostPosted: Thu Nov 04, 2004 12:29 pm
yeah...you could get the sound and lights going everythime you started up :lol:
play 3d car games for free
PostPosted: Thu Nov 04, 2004 4:09 pm
How about a Red one...and you push it and it Glows...Then When you turn the Key it Flashes. Now this would have to be around 2" in Diameter....For the untrained Eye.....They may think the Car inabout to Explode :P
 Post subject: How about....
PostPosted: Thu Nov 04, 2004 4:16 pm
What about a little dancing Ballerina that turns to sound of the "Self Preservation Society" from "The Italian Job" :shock:
PostPosted: Thu Nov 04, 2004 4:28 pm
Yer that will be good To
PostPosted: Thu Nov 04, 2004 4:31 pm
They are comming thick and fast now...How Bout a James Bond Style...Instead of a Centre Console Arm rest with Buttons and Lights, You could have a Little pannel on the right of the steering wheel with the buttons and flashing lights.. 8)
PostPosted: Wed Nov 10, 2004 11:47 am
i did actually have the idea that when you turn the ignition on, the button lights up and one the engine starts, the light goes out...
but then... it make it easier for a stupid thief to start the car .. :?
PostPosted: Wed Nov 10, 2004 12:03 pm
Thats why I liked the Flasing light :lol:
PostPosted: Wed Nov 10, 2004 1:30 pm
When me mate did up his RX3 13BT, He had a push button starter from Jaycar I think, the key would be turned to on, then he had a little circut wired through a reed switch and relay, he hid the reed switch behind the the front of his dash near the gauges. So to start the car you needed to brush a magnet up against the dash to close the reed switch, this then closed the realy and allowed the push button starter to start the car. Was quite clever.
PostPosted: Wed Nov 10, 2004 1:38 pm
Hanra wrote:
Was quite clever.
Assuming it wasn't prone the ignition problems generic to rotaries. :P
PostPosted: Wed Nov 10, 2004 1:41 pm
Series 6 twin turbo block, converted to single T66. Full Wolf 3D Engine Mangement. Aint no problems with this rotor!!
PostPosted: Wed Nov 10, 2004 1:51 pm
Fair assumption then. :lol:
