It is currently Tue Jul 22, 2025 6:50 pm
PostPosted: Tue Oct 10, 2006 7:45 pm
Whee is the best place to get replacement hologens for front headlights?
Thanks
PostPosted: Tue Oct 10, 2006 7:48 pm
In Supercrap I saw semi sealed beams for $17.95 each, check if they will take an H4 bulb. I forgot to look inside. :wink:
Hella H4s are around $150/pr I think, I brought in Wipac Quadoptics from Mini Spares in UK. Cost me around $90/pr I think, was a coupla years ago.
 Post subject: lights
PostPosted: Tue Oct 10, 2006 7:57 pm
yeah repco sell semisealed and take h4 like 15-20 dollars cheapest option
PostPosted: Tue Oct 10, 2006 9:50 pm
The two big things with halogens is;
1. The heat generated by the bulbs can and will tend to melt the connectors and the wiring. Don't go overboard with the wattage. keep it sensible and the lights will still be good.
2. The switches on a mini barely cope with the load with normal sealed beams and they definately dont with big H4's. You will definately need a set of good relays for the H4 lights. If you dont, you will burn out the light swithc at a time when you least need it to fail - late at night on a dark road. Its about $100 for the relay and the labour at an auto leccy.
Having said that, I have 120 watt H4 halogens in my mini and they work better that the halogens in the VN commodore - simply light up the night.
I had a little talk with a kangaroo last night in the commodore because the light just did not light up the side of the road where the roos cunningly disquise themselves as stumps until its simply the very last second.
Just a soft talk though, he whacked his tail on the plastic bumper and luckily he wasn't spun into the front guard or door.
PostPosted: Tue Oct 10, 2006 9:58 pm
I used the New Era headlamp relays, around $35 from Supercrap etc.
Piece of cake to wire up.
They also have 2x 30A blade fuses in them- good idea, as a standard Oz Mini has NO FUSES in the headlamp circuit.
PostPosted: Tue Oct 10, 2006 11:12 pm
Yea i have 60/100w Hella H4's and they have a better beam than our VT commodore :shock:
PostPosted: Wed Oct 11, 2006 6:39 am
Better than the crap angel eyes you had and cooked, eh.... :lol:
PostPosted: Wed Oct 11, 2006 9:20 am
a grade panels sell's some, im not sure about the brand but they are $60 incl globes
PostPosted: Wed Oct 18, 2006 10:30 am
I'm not to sure what the law is re:wattage etc, but in the UK, by far the best option is the WIPACS Conversions.
A nice looking unit, interchangable bulbs (H4 IIRC) and a whole lot brighter than the stock sealed units.
Working on a mini is like wallpapering your living room through your letterbox!
Users browsing this forum: Bing [Bot], fuzzy-hair-man, slacko, winabbey and 86 guests
