It is currently Sat Jul 19, 2025 3:25 am
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Oct 12, 2006 7:13 am
Matt TheMiniMan has done heaps like this, with holes in, he's never had one break.
Likewise GR.
My 1310 regularly saw 8000 on the track, no problem.
I think facing them off .200" is fine, I'm just wary of drilling big holes or (worse) milling slots thru them.
If you want it that light, go buy a steel one.....
BTW if turning them, make sure there's a nice big radius on the lathe tool, you don't want a sharp corner at bottom of cut. :wink:
And they MUST be rebalanced afterwards.
PostPosted: Thu Oct 12, 2006 7:26 am
jbeenz wrote:
if it flys apart, im a little worried about my feet, and legs, but very very woried about other parts! how likley are they to break up, and if so, make it into the pssenger compartment?
I don't personally know about a flywheel but I've seent he results of a couple of clutch plates exploding and their pieces made it into the cabin , if you are concerned in any way and the car is going to be given a hard time put a scatter shield around the clutch housing , the cast alloy isn't all that strong against flying components ...
PostPosted: Thu Oct 12, 2006 7:32 am
that sounds like a plan! im sure id regret it the one time i ended up like buck shelford (ah ha an all blacks comment!)
PostPosted: Thu Oct 12, 2006 8:30 am
willy wrote:
slinkey inc wrote:
yeah 'tis best to use a replaceable one such as a standard clubby type steel one. easily replable, thats probalby what you got.
It is for my race motor.
The one i have spent copious amounts of dollars on :shock:
:lol:
I thought all Mini flywheels were cast...
William-you could spend your money on something like this....
I don't have any problems about stalling the engine,as you are always using plenty of rev's anyway :roll:
PostPosted: Thu Oct 12, 2006 9:01 am
How much :D
PostPosted: Thu Oct 12, 2006 5:00 pm
willy wrote:
How much :D
If you have to ask, you can't afford it.
Ask Minisport SA. :wink:
PostPosted: Thu Oct 12, 2006 5:04 pm
No thanks... not buying from there anymore if i cant help it!!
:shock:
PostPosted: Thu Oct 12, 2006 5:07 pm
Upon chats to GR today, I will be most likely bringing my flywheel and backing plate over to him when i am there for MDU, and getting him to machine it up and get it back to me.
He will machine .250" off the face, and also bore the outsides. This does not affect the structural inegrity of the flywheel.
I am not sure of exactly how he will be machining the backing plate, but that will be modified also. :D
I am buying a super-dooper 5.5" GR manifold, too.!!
(He's porting one out for me, will be ready by MDU)
GR reckons the one-piece flywheels are better to start with...
I forgot to ask why.
Does anyone know why?
PostPosted: Tue Oct 17, 2006 11:39 am
is lightening the flywheel a good thing for a road motor? or only race ones...
PostPosted: Tue Oct 17, 2006 1:14 pm
:shock:
I understand :wink:
Go straight to the source, buy from the UK. I would heartily recommend that everybody avoids the mini spares ultrlight steel flywheels. The one I had and sent to GR for balancing was about 40 thou out of round, bent 35 though with the ring gear having a run out of over 45 thou!!
All this = REALLY BAD vibration, lots of $$ wasted and me getting severely pi#$%^d off. (yes, AFTER it was Balanced.)
If you want ultralight steel get it from someone reputable such as MED engineering. About $850 for ultrlight fly, back plate new cooper s spec clutch plate, orange pressure plate, straps etc, all assembled and balanced! That is our price including freight!! 8) 8)
Or spend $550 or so on one from here? (bare flywheel) :lol: :lol:
Won't do that again!!
PostPosted: Tue Oct 17, 2006 1:17 pm
GR is doing my flywheel.
I have heard a one-piece is desirable, as it does not tend to 'weld' onto the taper of the crank, due to the big difference in metal types.
So I will hunt down a one-piece before Friday when I fly over to Syd :lol:
I am taking a backing plate too, he is lightening that also.
PostPosted: Tue Oct 17, 2006 1:19 pm
Cos they are lighter than the two piece :wink:
PostPosted: Tue Oct 17, 2006 4:29 pm
Hmmmmmmmmm anyone got a one-piece lying round that I can buy?
PostPosted: Tue Oct 17, 2006 4:38 pm
What model's had em? I got spare flywheel, from 850 so I guess being an 850 it would be undisirable....??
PostPosted: Tue Oct 17, 2006 4:43 pm
Have a look to see if the centre is held to the rest of it by 8-10 bolts , can't remember how many but it will be obvious . Can't remember what had what but I think 850's should have had the two piece version .
Users browsing this forum: No registered users and 116 guests
