It is currently Sat Jun 28, 2025 12:30 am
PostPosted: Tue Oct 24, 2006 11:43 am
Hello,
POR15 comes in a kit with 100Mls of anti rust coating. How many 100Ml tins do I need to do 2 coatings (at least) of the entire firewall and some dide bits of the engine bay?
Lillee - 1969 Morris Mini K
PostPosted: Tue Oct 24, 2006 12:30 pm
Probably 1 or 2 is enough. It's pretty easy to overestimate how much you need. And once you get some out, you can put the unused portion back in the tin.
Are you brushing on?
PostPosted: Tue Oct 24, 2006 1:36 pm
Yes I plan to brush it on.
I want to use the Tie Coat primer as well, sand it back then spray colour matched enamel over the top. I think this is all I need to do?
PostPosted: Tue Oct 24, 2006 4:20 pm
Chong you need the marine clean and metal ready too before you paint.
You don't really need the tiecoat, just sand with 600 and then you can paint over it.
Also DO NOT pour the paint back into the tin (i have though - more of a do as i say not do as i do), the instructions for the paint say never to pour any unused paint back into the tin or to ever get any water near the paint in the tin.
I have painted half of my firewall, used bugger all paint.
Make sure you read the instruction at least twice too :wink:
PostPosted: Tue Oct 24, 2006 4:30 pm
I am planning to buy the kit which ones with marine clean and metal prep.
So you did your firewall with 100mls???
Thanks for the info by the way!
PostPosted: Tue Oct 24, 2006 9:27 pm
As mentioned on MSN I don't know what I ue on the fire wall but I hink 100ml maybe be underr but call the contact I gave you
Alos I belive you can Primer on top of the sticky POR15 if you wish to Colour the top coat :wink:
If you don't want Gloss Black
PostPosted: Tue Oct 24, 2006 10:46 pm
Does it not give the coverage rates anywhere?
PostPosted: Tue Oct 24, 2006 11:09 pm
nowhere that I can find unless someone has this info?
PostPosted: Wed Oct 25, 2006 6:40 am
According to my brochure, (p eight) 1.0L covers 10M2. So 100mL will cover 1M2:wink:
rant/
WTF does this forum's US software give you a smiley instead of the number eight.. it pisses me off).
/end rant
