It is currently Sun Aug 03, 2025 6:39 am
PostPosted: Wed Nov 01, 2006 10:04 pm
Or hear crackling sounds...
PostPosted: Wed Nov 01, 2006 10:06 pm
Aussie, flames? Is that from experience? :lol: :shock:
PostPosted: Wed Nov 01, 2006 10:51 pm
any one got any pictures???
ive got this one, and its one of the custom ones ive seen that i think look good... but are they digital???
sorri for the large image :oops:
PostPosted: Wed Nov 01, 2006 10:57 pm
nope from my experience you look down at ur feet and you see water rising at an incredibly rapid rate before you realise you need to get the f$%^ out before you drown :wink:
never had flames though
PostPosted: Wed Nov 01, 2006 11:10 pm
:lol:
PostPosted: Wed Nov 01, 2006 11:26 pm
whatever happened to just a speedo and fuel gauge from the 850's
(which probably never worked properly anyway)
no water temp, oil pressure, volts to worry about
on the contrary, i LOVE a dash with 20 gauges on it... feels like you're flying an aeroplane
"Fuel? check. Battery? Check. Oil pressure? Check. Op Temp? Check. Seat Belts? Check. Wipers? Check. Brakes? Check. Extinguisher? Check. Doors? Check..."
Inconspicuously Conspicuous
PostPosted: Wed Nov 01, 2006 11:57 pm
NAV-MAN
Yep they're digital. They look like dakota digital guages.
Just like this panel I made earlier (NOT!)
MMMmmmmm digital. 8)
Here's a nice replacement for that boring old 850 speedo :D
They can even switch between m/ph and km/h.
heaps more www.dakotadigital.com and they aint cheap.
PostPosted: Thu Nov 02, 2006 12:21 am
they look sweet tho 8)
well i mite as well start saving now :roll: :lol:
PostPosted: Thu Nov 02, 2006 10:52 am
Wasn't there someone on here with a story about electrical problems causing their brakes to fail? Good story.
PostPosted: Thu Nov 02, 2006 11:58 am
Mini Mike wrote:
K.I.S.S. willy???
i'd rather not
78 Leyland Mini - Prince
PostPosted: Thu Nov 02, 2006 12:16 pm
resident alien
resident alien
2 S's & a clubman wrote:
willy wrote:
I'd omit oil temp and volts... not necessary.
Don't overdo it... K.I.S.S. :wink:
WRONG willy, volts are very nesessary, they show up the 1st sign of any electrical dramas, oil temp is'nt rally needed
Doogie
I have Speedo, Tacho, Fuel, Water temp, Oil pressure and Volts (good for telling when the alternator kicks in :D )
PostPosted: Thu Nov 02, 2006 12:53 pm
i used to have heaps of gauges, but got sick of them taking up dash space, canned them all and stuck with a rev counter, but i dont even look at that.
gauges are good to have but i agree with other people here on where to stop, no need for too many.
just stick to a oil pressure and water temp.
im soon to fit an oval dash to my mini, which has a combined water/oil on the left, speedo in center and small 52mm tacho on the right.
k.i.s.s
 Post subject: gauges
PostPosted: Thu Nov 02, 2006 1:37 pm
Since i've got a passenger seat in mine and do a bit of touring / rallying, i've set it up for a driver / navigator design.
Essentials (read - important ones): tacho, water temp, oil pressure (drivers side).
Less-Essentials (usually don't cause the engine to blow up): fuel, voltmeter (passenger side).
I'm deciding whether to add an oil temp guage to the less-essential (passenger side). It'd be good to know, and you could test different grades of oil and see how it interacts with the engine. How else do you know what temp your oil is running at? From memory 200 - 230 degrees Fareignheit is optimal.
re: volts - you can survive without one, but if it's a race car, you've got a batt. isol somewhere near the dash anyway (ie. easy to hook up). It would only be useful to see if your alternator isn't generating enough voltage, or for troubleshooting.
Speedo - who cares :) I hate connecting / mounting the speedo gauge/ short cable - it's big, heavy and gets in the way of everything. Just put a conversion chart up... (rpm -> kmph) and save some weight :)
