It is currently Sat Jul 19, 2025 7:18 am
PostPosted: Sat Nov 06, 2004 3:00 am
Wow, it seems i cant even keep to MY OWN topic. :lol: That sux.
PostPosted: Sat Nov 06, 2004 2:42 pm
hey skssgn,
i believe your mini was closer than 100mm from the ground at the start of the year! lol
sorry mate had to be said, ne way hows the van comin along, me old man was sayn u got sum pretty expensive plans for her!
Rohan
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
PostPosted: Sun Nov 07, 2004 8:35 am
If yer car came out of the factory with that option then it's legal. They cant say crap, because the manufacturer had to pass all ADR's to make them legal. If the mini came out Lower than 100mm, too bad.
Rearward facing bonnet scoops are illegal(if the engine blow up it'll throw oil over the windscreen). But if ya have an A9X Torana, they cant do diddly about it, coz that's how it came outta the factory.
ADR's BLAH BLAH BLAH
PostPosted: Sun Nov 07, 2004 11:12 pm
couldnt u buy factory made supercharger kits for ur mini. so like it was a factory accesory u just couldnt buy it with one from the factory..
kev?
PostPosted: Mon Nov 08, 2004 12:06 am
what if you say it's an replica M-30?
http://www.miniresource.com/bacm30.htm
then you should be ok.. :)
Ok, here's another one of South Australia's funny rules....
Aftermarket bonnet scoops MUST open rearwards.
I bolted an UNMODIFIED Holden Jackaroo scoop on my Mazda, it doesnt even block my vision, but its illegal cos it faces forwards - just like on a Jackaroo.
The mini factory didnt produce Supercharged Minis. The kits are ALL aftermarket.
In South Australia, you can supercharge ANY car built before 1969....WITHOUT getting it engineered :wink:
PostPosted: Mon Nov 08, 2004 12:18 am
This car is not comparable to other minis in SA. The shell was built by "Rover", which is a different manufacturer to Morris and Leyland, so technically its an English 1989 Rover Mini shell. It has totally different rulings to the Austrailan minis, and is regarded as a totally different car. Stupid, huh!
PostPosted: Wed Nov 10, 2004 11:58 am
TransportSA wrote:
The fitting of forward opening bonnet scoops, which have the potential to increase injuries to pedestrians in collisions, for example forward opening "letter box" style, are not acceptable.
i'm sure there are "pedestrian friendly" forward opening scoops...
just stirring things up a bit.. ;)
PostPosted: Wed Nov 10, 2004 4:33 pm
nath (sc850) sent over this info about mods etc.
before 69 and basically ur in the clear.
my flipfront, technically is legal. :D
PostPosted: Wed Nov 10, 2004 4:35 pm
nothin technical about it..
it isn't sharp... so it's legal..
and you don't need a cert.. ;)
PostPosted: Wed Nov 10, 2004 11:29 pm
Another thing that worries me...
Im not sure if the wank.... um.... BOYS at regency are allowed to say "We still want a certificate to prove that its strong enough"....... Are they able to override the rules if they dont THINK its safe?????
PostPosted: Thu Nov 11, 2004 12:12 pm
it's certainly wobbly enough... ;)
