It is currently Sat Aug 02, 2025 11:09 pm
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Fri Nov 10, 2006 7:52 pm
PS - the stubby I would do is one of yours.
PostPosted: Fri Nov 10, 2006 7:58 pm
Slow-Po
Mike_Byron wrote:
just where is queens park
Next to Bondi Junction. 8)
 Post subject: Re: Plugs
PostPosted: Fri Nov 10, 2006 8:01 pm
Has it run beefore :?:
-12months ago before the engine came out.
If so, remove number one plug, put HT lead back on...hold it up against the block (earth - you do have an earth lead from the bottom of the clutch cover to the subframe :?: don't you :?: )
-Yes earth is well and no spark.
Get an assitant to crank her over or short out the solenoid bolts yourself (just quickly)....see if you get a spark across the spark gap. If you get one...you could try the other three to give you some confidence.
But :!: more importantly, have you had the distributor out :?: loosened off :?:
- No dissi hasnt been out or loosened off
Its been sitting for twelve months. I will replace the coil tomorrow and go start again.
PostPosted: Fri Nov 10, 2006 8:05 pm
Thanks for the offer.
PostPosted: Fri Nov 10, 2006 8:06 pm
Slow-Po
:idea: What about when we picked up the moke and the front subframe flipped forward :?: :) Cursed Blue Cow.
PostPosted: Fri Nov 10, 2006 8:09 pm
No the dissi hasnt been out of the engine. :P The entire engine assembly has been out of the car.
But I am looking forward to firing the exhaust free engine towards misery guts across the road. :lol: :lol:
PostPosted: Sat Nov 11, 2006 10:16 am
The latest:
A went end put in a new coil.
When the engine is turning over off the starter:
8v - . 8v +
When the engine is not turning over
12v both sides
So I assume I have an earthing problem somewhere
Still no spark to the head from the coil from the HT lead.
 Post subject: HT??
PostPosted: Sat Nov 11, 2006 10:52 am
back to the points....whip the dissy cover off and see if you are getting spark across the points....that could mean the dissy cap is breaking down or you have a lead or three thats cactus :idea:
 Post subject: Re: HT??
PostPosted: Sat Nov 11, 2006 10:55 am
Thanks. Bloody thing. Maybe I could just set fire to it.
PostPosted: Sat Nov 11, 2006 11:00 am
Good idea :!: can I get the good bits out first tho :twisted:
Points...are they new :?: ...if so give them a thorough check over (especially the faces, bright shiney :?: and the insulation as Jon said above). They are adjusted correctly :?:
PostPosted: Sat Nov 11, 2006 11:03 am
ish- bright and shiney, they have worked as installed.
PostPosted: Sat Nov 11, 2006 11:18 am
Thats would be wrong. They had melted that might make it a little difficult to start- new points coming right up.
 Post subject: Points
PostPosted: Sat Nov 11, 2006 11:23 am
Just make sure you don't overtighten the insulator so that it cuts through...and make sure the faces of the NEW points are free of oil/protective coating etc..maybe carefully clean with turps/metho first.
Don't forget a tiny bit of silicone grease behind the pawl :idea:
I'm off to a driving and guitar lesson....both for my son :lol: Good luck :!:
PostPosted: Sat Nov 11, 2006 11:38 am
re check the earth also, make sure brake lines etc are not getting hot under electrical load, ok and add an extra earth for luck :D
PostPosted: Sat Nov 11, 2006 11:40 am
brake lines what brakes lines :lol: :lol: thats the next job
