It is currently Fri Aug 15, 2025 11:43 pm
 Post subject: wet or dry?
PostPosted: Sun Nov 19, 2006 10:39 am
hey guys just wondering whether a 1978 mini would have the wet or dry suspension as im considering doing the conversion.
PostPosted: Sun Nov 19, 2006 10:52 am
If its an Australian built clubby then it left the factory with dry suspension. But the good thing about minis is that so many things are interchangalbe. Somebody could have swapped things along its life.
Just lift the bonnet and look at the corners of the bulk head / firewall near the clutch and brake master cylinders. If there is rubber hoses coming out of the subframe towers then it is wet. If there is none then it is dry. Simple
Dont get confused with heater hoses which go through the firewall.
PostPosted: Sun Nov 19, 2006 11:06 am
i would if i lived in ipswitch because thats where the car is.how do you tell if its australian built or imported?
PostPosted: Sun Nov 19, 2006 11:11 am
Aussie built have 1/4 windows, imports just have one big windup window :wink:
PostPosted: Sun Nov 19, 2006 11:22 am
so this is an australian built mini?
http://cgi.ebay.com.au/1978-Leyland-Min ... dZViewItem
and can anyone tell if this would have the wet or dry system in it?
PostPosted: Sun Nov 19, 2006 11:41 am
Yes - from that photo - the car featured is an australian built clubman and the shot in the engine bay shows a dry suspension setup.
PostPosted: Sun Nov 19, 2006 11:51 am
thanks for your help guys it was much appreciated
Users browsing this forum: Majestic-12 [Bot] and 367 guests
