It is currently Tue Jul 22, 2025 6:14 pm
PostPosted: Fri Dec 15, 2006 8:54 pm
im trying to bolt the back together and i can tighten it to a certain point but then it starts turning round like you have to hold on to something to stop turnig
so my q. is how do u do this
sorry if this doesnt make much sense im new to this
thanks nathan
1969 mini k
PostPosted: Fri Dec 15, 2006 8:59 pm
Provided both parts are paint, dirt and grease free, they should be fine.
some light taps with a fibre hammer may help settle the joints in a bit.
Put some copper grease on the retainer nut too.
:D
PostPosted: Fri Dec 15, 2006 9:19 pm
Put some weight on it, ie with the jack under the bottom arm.
Daniel
PostPosted: Fri Dec 15, 2006 10:40 pm
what he said, jack from underneth act as your hand, i was told to also add a flat washer with a lock washer,
PostPosted: Sat Dec 16, 2006 10:21 am
Like they said above - put a jack under and carefully pump it up a bit or the other way is to lower the car down with a length of 4 x 2 (or similar) on its end (of course) under the ball joint.
Happy Chrissy
Rod Image
PostPosted: Sat Dec 16, 2006 10:26 am
A lock (spring) washer should not be used with a flat washer. It defeats the purpose of the spring washer... as the flat washer can spin it undone. :wink:
PostPosted: Sat Dec 16, 2006 10:32 am
so i allready have so what should i replace it with
PostPosted: Sat Dec 16, 2006 11:36 am
A new spring washer... :wink:
The idea of a spring washer is the ends bite in and prevent it unscrewing.
Alternatively, use a Nyloc nut, no washer needed.
PostPosted: Sat Dec 16, 2006 11:53 am
but then it would chew into the rubber or it that ment to happen
