amrmeaner wrote:
I bought a new radiator from Minisport in SA on Ebay. Fast delivery and good service.
Radiator works find.
http://cgi.ebay.com.au/MINI-3-CORE-RADI ... dZViewItem
I run one of those. It has already shaken the side bracket from the top tank (is just soldered, has no rivets).
They have less fins than your old one. And, the top hose location is wrong for a 77S, unless you change the thermostat housing
<edit> and bracket for an earlier one, and lose the air pump (if fitted).
<edit> 77clubmnS, it CAN be recored, new cores are available still. Any radiator shop, or Natra radiators. But get it checked first.
Also check the thermostat, it may have stuck and caused the problem. Mine did last week.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
