It is currently Sat Jun 28, 2025 1:01 am
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Fri Jan 05, 2007 5:26 pm
Great work :D
The kit idea sounds great :wink:
Matt
 Post subject: pistons
PostPosted: Sun Jan 07, 2007 6:12 pm
hi would luv to build a turbo engine for lego but am not sure what i need. ive got a spare 998 at the engine shop now getting acid dipped and crack tested and have a set of 60 thou standard pistons will these be ok to use in a turbo motor. and r the bearings special as well?
cheers matt
i like to drive on rails
 Post subject: Re: pistons
PostPosted: Wed Jan 10, 2007 5:06 pm
cheers matt
im using hypatec 60+ pistons in mine so far with 6psi boost and no troubles, bearings are just your normal bearings. the only thing that is really different is the compression and cam (dont want a massive cam).
anyway a bit of an update hadnt done much this week as i was waiting for my carbide burrs to arrive so i could grind the inside of the pipe as i went along. They finally came today so managed to get a little more done.
also had a little play with my tig tday and managed to weld some alluminium without it melting into a ball :)
oh and about a kit maybe one day but deffinatly not for a while , wait till this is all sorted and no bugs in it. wouldnt want any problems. Also they would be alot of parts to change or source for it as the manifold is just one of many items needed, you would need a sutable high pressure pump + regulator ,new exhaust , Metro turbo carbie + manifold + plenium and the turbo air filters things like that.
PostPosted: Wed Jan 10, 2007 5:38 pm
sounds like a decent kit then
PostPosted: Sat Feb 24, 2007 8:51 pm
not really much to update , manifold is finished , but is off being skimmed at the moment then is off to be ceramic coated ,will take some pictures when its all done.
and megajolt bits are all mounted
thats all that iv really done atm
saw this on sale and well i bought it :P (electronic boost controller)
PostPosted: Sun Feb 25, 2007 7:51 am
Can you get FM on that? :lol:
Great work so far! 8)
Sir Alec! we are not worthy!
PostPosted: Sun Feb 25, 2007 10:58 am
good work buddy, cant wait to see how this one end up
PostPosted: Mon Feb 26, 2007 7:18 am
great work ben..... engine sounds like a real tromping machine. Good luck with the rest of the freshening up. Engine thus far looks the "goods". Bet your very proud of the work you've done because its very proud worthy.
PostPosted: Thu Mar 01, 2007 7:57 pm
looking great ben, will be a missile with all the new gear mate.
That boost controller is regarded as one of the best on the market and will hold boost awsome, and bring it on alittle earlier too.
1974 Moke - 998cc
PostPosted: Mon Mar 26, 2007 6:06 pm
another update,
i was original going to buy a new garrett Gt15 but after some reasearch and looking at them my hiflowed t2 should produce more hp. My T2 had seen better days had alot of play in all directions :o so was in need of a rebuild. The turbo was dropped of at GCG turbochargers in condell park (http://www.gcg.com.au/) and fully rebuilt and balanced.
next as i want to run an intercooler i dindnt want to use the standard plenum as it would make the piping messy as the pipes would have to go back across a hot engine. So an stainless steel copy was made by nic on turbominis.co.uk and sent out here. These copys have the plenum intake on the oposite side making intercooler piping much neater , also look nice :)
last in the pic is the computer that controls the spark The MEGAJOLT.
 Post subject: nice
PostPosted: Mon Mar 26, 2007 7:12 pm
very nice. im looking on with great interest, keep the updates coming. :lol: :lol: :lol: :lol:
PostPosted: Wed Mar 28, 2007 6:46 pm
Got the manifold and dump pipe back today, was ceramic coated by a place called Turbo Exhaust Centre in Smithfield.
they did a great job and would recomend them to anyone doing the same.
PostPosted: Wed Mar 28, 2007 7:30 pm
They do look pretty good. What sort of price are we looking at for what you had done there?
Dan
Life's a garden.... Dig It!
PostPosted: Sun Apr 01, 2007 6:04 pm
Dan
around $225 for 4cyclinder manifold , but he has to have a look for proper quote.
Now for the fun stuff :P megajolt + boost controller add on loom
PostPosted: Sun Apr 01, 2007 6:39 pm
Looks the dogs bollocks man, i'm well impressed!
