It is currently Sun Aug 10, 2025 4:59 am
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jan 11, 2007 6:27 am
buztoy wrote:
allthough not discoverd yet i reckon there would be something magic wander sort of chemical that could do, all they need to do is to stop the iron particles to stop oxidising, i repeat it has nt been invented or discovered,
its a big call and could be placed on the same level as getting pigs to fly but i still reckon it could be done
It's already done, it's called phosphoric acid. :lol:
It converts the iron oxide into a phosphate coating, all you need then is a paint system that denies it air..
Some products also give it a hard resin-like surface that helps seal it.
When I did HaHa up 13 years ago I used Permatex (now called Loctite brand) rust converter on the back seat join after wire brushing, and I left it `black' and never painted it. Today, it still looks the same. So yes it works. :wink:
PostPosted: Thu Jan 11, 2007 9:51 am
I was looking at "rust converters" the other day as I needed to buy some more. Some brands didn't state what was in them some did. I was looking for the highest concentrations of Phosphoric Acid and noted the fact that those that stated they had the acid also had the appropriate Poison Schedule labelelling - POISON in the box and Keep out of reach of Children etc at the top of the label, while the ones that didn't state what was in them didn't have any schedule label. I can't put my hands on the Poison Schedules at the moment but my guess is lack of labelling indicates a low concentration of acid (as it is used in some food stuffs eg CocaCola and would need a low cut off for labelling as a poison)
Highest concentration of acid appears to about 35% and price does not reflect concentration - Brand does :evil: with the most expensive not stateing it has any acid in it
David L
PostPosted: Thu Jan 11, 2007 2:02 pm
It used to be sold under the name deoxidine, wipe over withrag and wash off withwater and rag, when it dries it hs a coaying of phosphate type stuff that will protect the surface for just long enoughto get the primer on, maybe overnight if your lucky and its a dry day :D
Jon
PostPosted: Thu Jan 11, 2007 3:26 pm
Hey Wombat! you're talking my language!
S.U.S.D.P. for phosphoric acid would be >35% to be schedule 6 and hence "POISON" on the top of the label! :shock:
<35% would be shedule 5 and should have "CAUTION" on the label, except when <15%, then outside shedules!
:P :roll:
Sir Alec! we are not worthy!
PostPosted: Thu Jan 11, 2007 3:35 pm
I make my own here at work :P
I prefer to add a solvent to the phosphoric acid like Ethylene Glycol Monobutyl Ether, then you can wipe / brush on and allow to dry as the solvent evaporates without a water rinse. I've found this will give the smooth phosphate grey coating and not rust again for several weeks.
I agree however that the best option is to prime (preferably non porous 2 pack type) as soon as possible after surface / rust treatment. 8)
PostPosted: Thu Jan 11, 2007 3:51 pm
:P :roll:
So that means the dearst one I saw had less than 15% active ingrediant or half the strength of the strongest that cost less :evil:
David L
