It is currently Mon Jul 21, 2025 8:23 pm
 Post subject: Clubman GT info
PostPosted: Sat Feb 03, 2007 6:00 pm
Hi guys, l'm not a real know it all with Mini's but I was wondering if anybody would be so kind enough to share with me the secrets of how to determine if a Clubman GT is actually a Clubman GT or not?!?!?! This car has the twin carbs, twin fillers & tanks, disc front brakes, but I do not know how to tell by year model or chassis number etc, etc if she is the real deal!!!! Can anybody please shed some light on the subject for me???? Cheers guys.
PostPosted: Sat Feb 03, 2007 6:01 pm
Have a look at the following web site;
http://homepages.ihug.co.nz/~gavin.agnew/pg2.html
Cheers Pete
PostPosted: Sat Feb 03, 2007 6:07 pm
whinja ninja
whinja ninja
hi and welcome!
IF you want to know for sure if its a clubman GT, contact GT http://www.ausmini.com/forums/profile.p ... ile&u=2472
He seems to be the resident expert on them, and should help you out. :wink:
I don't know my name anymore.
PostPosted: Sat Feb 03, 2007 11:12 pm
Hi,
Some of the easier things to look for are;
Compliance plate under the bonnet front drivers side reading YG2S8----.
That same digits YG2S8----, stamped on the radiator cowling.
Behind the master cylinder on the firewall should be stamped M23, and then the numbers approx. 500 less than the four YG2S8 ---- following digits.
The vehicle should have 7.5 front discs with VH44 brake booster and hydrolastic suspension.
Washer bottle next to the radiator(near the grille).
Oil Cooler secured to the bottom of the front apron.
Engine should be 1275cc with prefix of 9F/XE/Y-----,1200/---- or1206/---- and 4 speed synchro remote box.
The dash has 6500rpm tacho redline and speedo is 120mph with kph inside.
The heater has two spotwelded retaining brackets.
Underneath the rear passenger seat is a 1/4 inch hole for the fuel pump breather.
Should have twin tanks with electric fuel pump.
The right hand fuel tank securing bracket should be welded to the boot wall.
In the boot should be 5 brackets to support the boot board(between twin tanks),2 left and 2 right breather line tags, 3 breather line tags on the under parcel shelf. As well as holes in the boot floor for the breather lines to vent.
These are just some of the easier things to find and should give you a good idea, if the car is genuine or not.
However buyer beware, if in doubt get someone to help verify the authenticity.
Good Luck
PostPosted: Sun Feb 04, 2007 12:49 am
Thanks heaps guys. As they say...... you learn something new every day. All the info is writen down & will be using it very soon. Will let you all know how I've gone when I get back. Once again thanks heaps.
PostPosted: Sun Feb 04, 2007 1:07 am
didnt read everyone elses posts but get what numbers you can off the car,
compliance plate
rad cowel or watever tis called
wiper motor?
engine
etc these pppl on here know there minis and will b able to tell u every little detail!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sun Feb 04, 2007 2:53 pm
GT's also had an electric fuel pump fitted from standard :wink:
I hope that it is genuine GT. you would own a very rare breed of mini if it is :D
Matt
PostPosted: Mon Feb 05, 2007 6:13 pm
Hi there again guys,
I used the info you all gave me to good advantage as I now have myself a genuine 5/72 Clubman GT.... but she aint real pretty so I guess that means time to break out the spanners & get stuck into a rebuild. She is missing a few things so i'll also have to chase some stuff up here & there for her. Pics will be coming along soon also so stay tuned people. :D
PostPosted: Mon Feb 05, 2007 6:51 pm
Well congratulations mate.
Doesn't matter how pretty it is or isn't - you got yourself one and that's all that matters.
Good luck with it 8)
Peter.
1982 Honda CB1100RC (ours)
Users browsing this forum: AWOODY, fuzzy-hair-man and 78 guests
