It is currently Wed Jul 23, 2025 10:05 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
Pulsar Dizzy Conversion;
Haven't done it 39%  39%  [ 17 ]
Done it, and very happy with it 50%  50%  [ 22 ]
Done it, and wouldn't recommend it 7%  7%  [ 3 ]
Done it, and took it off 5%  5%  [ 2 ]
Total votes : 44
PostPosted: Mon Feb 05, 2007 9:32 am
slinkey inc wrote:
The two main reasons for this 'Pulsar Dizzy Problem' as stated by another Ausminier happy with his mod. Is, seizing, and over-advancing. You do need to know what you are doing before you do it. Unfortunately the problem on Ausmin that many people complain about is that 'it is the wrong curve', and yes it is. But is the stock one right for a modded engine, and the answer is no it isn't. The only problem with the nissan one over a Cooper S one, for decently powered mini's only. Is the lack of early advance. The Nissan one never overtakes the 'S' one in terms of total advance at any given point, but almost equals it. The problem I had with the 850 dizzy, was lack of advance high up, as the 850 dizzy isn't meant for total performance. The 'S' one is. So really, the Nissan dizzy is less dangerous that putting an 'S' dizzy in. Basically never change to a differnet curve without thinking first. The early flat spot, is due to lack of advance, hardley dangerous, engine may run hot, but at 1500 rpm, I don't think i care, I'm always above that anyways. By all means, stay with the Morris one, nothing wrong with points, I changed due to wanting a Cooper S like curve but I just couldn't afford the 'S' dizzy.
Note - Over advancing can happen with any dizzy. If you set a stock, or 'S' dizzy statically to high, it have trouble starting and all, but it can, and probably will blow the hell out of your motor, it's all relative.
Back on this thread, as a conclusion. The Pulsar dizzy is good as an alterantive to an 'S' dizzy when more total, higher rpm advance is required. If your running a farily stock small bore, a Pulsar dizzy, is not an improvement really. But on anything high power it is. I know a guy running a stock D4R85 in his supercharged bigbore, he races it, and he's never had a problem.
I just want to add that the gain in engine power due to running a younger less worn out dissy should not be mistaken with the pulsar dissy being the right curve and producing power.
The trouble with what you are saying is that many people do run a pulsar dissy on their relatively stock motors. I myself was one of these people. Once modifed to have less total advance the gains were enormous. Some of the pulsar dissies are up to 18 degrees total advance at high RPM which is probably 5-8 degrees more than necessary. This means too advanced running at high rpm, a situation that happens all the time: freeway running.
I have heard of several people blowing head gaskets and piston rings on their relatively stock 1098's so be careful. Be very careful when mucking around with your Mini dissy curve...
PostPosted: Mon Feb 05, 2007 12:20 pm
This `perceived Pulsar problem' has been blown out of all proportion. You can stuff a motor by `power timing' a Lucas too, if you just keep twisting the advance up....
Anyway, a stock 1098 dizzy #40899 had 16-18* centrifugal advance built in. That's MORE than a Pulsar.
Cooper S and 998 Cooper both had 14-16* new, more when worn.
There are 10 different A series dizzys with advertised advance of 15* or more. I have all the type numbers here.
Max advance plate I've seen in a Pulsar is 15*.
I rest my case...
:lol:
PostPosted: Mon Feb 05, 2007 12:28 pm
Your dead right Kev,
I have recently done the same research, before promoting the conversion, and found the same data.
Its like everything, its all a big craze, then one person has a dodgey half assed attempt, then everyone follows n jumps on the band wagon. Back off, howmany other people have introduced something innavative (spelling) and new to the mini scene, at a decent price?
Dont get put off by it Doc, Give em hell
-Cam :evil:
IS NOW BACK ONLINE AFTER SOMETIME..... SORRY TO ALL, FOR NOT REPLYING TO PM'S!!
PostPosted: Mon Feb 05, 2007 12:44 pm
when i get around to it i'm just gonna go with the sensible option..
a hundred and what ever dollars and less head fiddle sticks.. :)
PostPosted: Mon Feb 05, 2007 3:01 pm
I am not saying they don't work, I use one with a modified advance plate.
If it is not the case and the pulsars really do work with the stock advance plate Kev, why did you modify your plate on both minis??
PostPosted: Mon Feb 05, 2007 4:34 pm
Ah ha, now this thread is getting good. Lillie I do agree, as I did say earlier, I will get a modded one done. Yes my dizzy was rebuilt, BUT it was obviously still worn. To me it's not points vs. electric. Just good curve vs. worn out one.
At the moment I'm happy with it. Dyno tune should be done in a few weeks along with the other mods, when i finish them. :lol: .
We'll see what the dyno operator says about the curve, Iread that they can 'design' a curve by running the engine to a given point, eg 2000 rpm, then adjsut to get max performance, record the require advance. Move up o 3000, do the same. So you could get a bunch of number, then put it on a graph, skecth a graph of 'best fit' and see if you can mod the dizzy, or get one built to suit your engine 100%. This would be costly, but the best option I reckon. Until you decide to mod your engine further.
As for Cush, I don't see the point in those kits, points aren't a big deal to me. But 'to each his own'
PostPosted: Mon Feb 05, 2007 5:05 pm
a hundred and what ever dollars and less head ****.. :)
But will it have the right curve?
PostPosted: Mon Feb 05, 2007 6:14 pm
I modified it because it works better at LOW-MID RPM. No different AT ALL from 3000rpm up, but of course I don't set it static anyway, which is where people get into trouble.
Set it at the maximum advance point, where it matters- use 28-30 degrees BTDC at 4000 rpm for most A series.
Whether it has a modded plate, or NOT.
You are missing the point here anyway Chong, it being that some Lucas have more centrifugal advance than a Pulsar, and so it's just as easy to over-advance a Lucas dizzy and get the same result.
Don't blame the messenger, or the dizzy. :wink:
PostPosted: Mon Feb 05, 2007 7:18 pm
i doubt mine would at the moment..
so anything is and improvement..;)
PostPosted: Mon Feb 05, 2007 7:46 pm
I ran one before any Pulsars, it worked OK in my 1310 except for Lucas spark scatter.
But the original Pertronix are not real reliable apparently, some people in USA are still blowing them up. Leave igniton on, and not running for a minute, and poof!... :cry:
see http://www.minimania.com/web/threadid/8 ... thread.cfm
PostPosted: Mon Feb 05, 2007 8:29 pm
i will be putting a modded D483R pulsar dizzy in my 1411cc stroker (how come you got an extra cc Doc, was it just a rounding error??), but it also has a 282 cam, will have a GR head, ported inlet manifold, 45DCOE weber, and has a rebuilt rod change with a Fred Sayers LSD in it.
As to why i chose the D483R, well with all the mods to the engine i would have had to have GR mod a points dizzy curve anyway. Frankly, as the 2 year engine changeout for my competition car :roll: shows, i have very little time or budget to work on the thing. So whenever i want to prepare the car for a track day, or whatever, one less thing to check (points gap) just suits me fine, as it is a few more minutes saved.
The engine is being built as a package, not a hotch potch of bits added on. I went to Graham, and told him what i intend to use the car for, what engine block, head, crankshaft, manifold, gearbox and budget for rockers exhaust etc were, and he has designed the package around those requirements. One of those requirements was reliability. As a result the dizzy will be modded using the dyno and the intended use and reliability requirements in mind. The maximum advance will be set using the dyno.
I have already pulled the dizzy apart and Graham had a look today. It was not the worst he has seen, but definitely needs cleaning up. I will do that and the oilway mods this week.
We shall soon see what it produces on the dyno, and i'll report on its reliability when i eventually get to use it.
I guess what this shows is it is a horses for courses thing. A pulsar dizzy is no cure all for a dying engine. if you are going to bother rebuilding an engine it is wise to rebuild all of the anciliaries as well as the guts. If there is a well priced alternative that you can rebuild and modify for the same price, then why not?
Another alternative is to go to jaycar and get a transisterised ignition kit, and build yourself a very low voltage circuit that does not destroy the points, and all you need is a soldering iron and literacy to make it work. That way you don't have the expense of a pertronix, but still have the same curve your engine was made with (assuming the engine and dizzy are stock and matched)
michael
PostPosted: Mon Feb 05, 2007 8:33 pm
mickmini wrote:
i will be putting a modded D483R pulsar dizzy in my 1411cc stroker (how come you got an extra cc Doc, was it just a rounding error??),cheers
michael
My 12G1505 crank is now 84.33mm stroke, it was (unused) std/std size and still is.
Your stroke may be a little less, if crankpins were not still stock size when offset ground. :wink:
actually mine is 1411.8cc 8)
Last edited by drmini in aust on Mon Feb 05, 2007 8:38 pm, edited 1 time in total.
PostPosted: Mon Feb 05, 2007 8:35 pm
not that there's anything wrong with that...
PostPosted: Mon Feb 05, 2007 9:27 pm
Hmm sounds like anything Lucas, maybe Petronix wanted to 'keep things real'. LOL.
Leave the old headlight circuit on for a minute, and poof, lots of smoke...HAHA, happened to me.
PostPosted: Mon Feb 05, 2007 10:14 pm
We seem to have two camps here love it or hate it. The hate-its reckon Lucas rock, so one that isn't worn out must be tops....
And STILL nobody wants to buy the brand new Lucas dizzys I've got OR the electronic Lucas one.
Grumble grumble.
And no, I haven't rigged up the electronic one so I can test it. Anyone got an A-series and wants to test it for me? Won't fit into my A+ engines.
M
