It is currently Sat Jul 19, 2025 6:57 am
PostPosted: Wed Nov 24, 2004 1:31 am
Chong it might be obvious but is your alt. belt tight enough? Coz it has to be much tighter with the bosch units. If you can make the belt slip on the alternator puley by pressing it down and spining the pulley manualy then its not tight enough.
PostPosted: Wed Nov 24, 2004 11:18 am
Hey mike, good question. I will check it again tonight but I got her started last night and the alternator was making around 14V so that's a relief. Kev tightenned it up for me when we installed it, it seemed ok at the time...
I think it could just a piss weak battery...
Duc, unfortunately the SU trick won't work for me, it's wasn't turning over let alone starting...
Lillee - 1969 Morris Mini K
PostPosted: Wed Nov 24, 2004 4:24 pm
With batteries, you get what you pay for. Bigger the better.
I run a Toyota Petrol 4WD one (Exide 550CCA) in mine, the Clubbie has a 550CCA marine one from my boat.. :P
 Post subject: ....
PostPosted: Wed Nov 24, 2004 6:37 pm
Location: thornleigh sydney...round crnr from suzitech!!!!
heheheh,
i feel stupid!,
im running a $50 cheapie from k mart!!!......
might get a good one through work!
cheers!
good info!!!
blake :wink:
ausmini member 195
71K 'Kaye', KAZZ69's work in progress
66 panelvan, going no where fast...
71 MS75 toyota crown COUPE :) yes A COUPE!
76 ra23 celica wid 1ggte, GT3071r, 13.5@106mph with alot of spinin....
wheels keep on turnin!
Users browsing this forum: Bing [Bot] and 77 guests
