It is currently Wed Jul 23, 2025 6:47 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Feb 15, 2007 6:39 pm
Hanra about that current drawing its not reading anything just 0.00
red probe to positive batt terminal and black probe to positive cable
PostPosted: Thu Feb 15, 2007 6:42 pm
I've oiled the SU maybe 2 months ago and the car was driving fine before.
checked the fuse and they all good, no shorting marks anywhere
I'm checking the alternator now...
PostPosted: Thu Feb 15, 2007 6:44 pm
Rob
if you have time on Saturday, give me a call and I can come over and we can both go over your problem.
David
PostPosted: Thu Feb 15, 2007 6:48 pm
On some multimeters u actually have to take the probe out of the multimeter itself and put it into the socket to measure current.? Or its a possibility that the internal fuse for the current measurement has blown?
Something must b causing ur battery to go flat. There should be some sort of current draw if there is a fault there...
Hi David
I'll take you on that offer David, will let you know
hopefully I can fix her soon
PostPosted: Thu Feb 15, 2007 7:51 pm
What's the 2 wire joined together connected on the power side of the solenoid, the connector facing towards the grill
its kinda brown not the bigger brown for the alternator
I got this image from the previous post... ites the yellow dot
PostPosted: Thu Feb 15, 2007 9:17 pm
I is a mookenik
looks like a ground wire but dude thats not the alternator that the dots are on? that pictures confused me lol.. i juz check under the bonnect of my mini to see if i can compare that pic with my engine and work out what is happening there but i cant i have a different set up.. juz wondering is it an alternator for sure u have or is it a generator
PostPosted: Thu Feb 15, 2007 9:57 pm
That wire should be going to the + terminal of ur alternator. That is the charge wire. It really should be heavier gauge then that!
I use green dot for the switched 12v from my ignition,
Light Blue dot: 12v from battery
Pink dot: i dont use
Yellow dot: I dont use
White dot: either + or - of coil
Gold dot: either + or - of coil
PostPosted: Fri Feb 16, 2007 12:06 pm
I'm sorry I should've stated above that I just found that pic from someone else's post
that pic is not my engine
I know the +ve thicker brown wire goes to the alternator but I have two more brown ones which are thinner than the brown power wire that goes to the yellow dot on the above pic.
I found one of the brown wire has a cut and very little of the copper is making contact so thought that might be causing the issue. But I dont think the wire I'm talking about is not going to the alternator.
I'm at work right now so cant take a photo of my engine bay.
PostPosted: Fri Feb 16, 2007 12:36 pm
That light blue terminal will just have 12v on it. So those other wires mite be for other accessories?
PostPosted: Fri Feb 16, 2007 2:47 pm
I just put my battery, left it overnight to recharge and I think my alternator is not charging the battery.
on Idle its 13.5V, 1500 - 2000 rpm and its only getting 14.0 V
then put the headlights on and the voltage on the battery went to 13.3V and slowly dropping
PostPosted: Fri Feb 16, 2007 3:07 pm
It shouldnt go over 14v 13.8 is ideal. But if the batt voltage is dropping then the alternator isnt charging. U shold b able to rev the engine and see the voltage rise.
PostPosted: Fri Feb 16, 2007 3:10 pm
I revved the engine and the voltage goes up very very slowly
PostPosted: Fri Feb 16, 2007 3:12 pm
It should be instant.
Take the alternator off and take it into a Auto Electrician, then can stick it on the bench and check it out in like 5 mins.
PostPosted: Fri Feb 16, 2007 3:15 pm
might just replace it with bosch pulsar one
Users browsing this forum: 78Clubbie, Bing [Bot], watsupskip and 108 guests
