It is currently Fri Jul 18, 2025 9:25 pm
 Post subject: Removing heater
PostPosted: Fri Nov 26, 2004 10:34 pm
Well i think its time to say bye-byes to my heater. I havent used it AT ALL in the winter months, and its just taking up space. Ok i think i can physically take it out, but what about the pipes that go into it?
I know that they come from the engine so i was wondering where i would put the pipes.
Hmm... any advice is good advice.
PostPosted: Fri Nov 26, 2004 10:52 pm
If your car was built to ADRs then you must have a demister/heater.
So if you pull it out it is just another defect waiting to happen!
PostPosted: Fri Nov 26, 2004 10:54 pm
Holy SHITE! Are you serious. Well im gonna do it anyway... they'd believe me if i said "No officer, this is an 'S'... they didnt come out with heaters"
:twisted: and as for demister... just open the windows a little.
PostPosted: Fri Nov 26, 2004 11:14 pm
Then there is the other problem of driving around on a rainy day with fogged up windows!
Another thing that most people miss is that the heater is part of the cooling system. So if you pull the heater out the car loses part of its cooling capacity.
PostPosted: Fri Nov 26, 2004 11:19 pm
Yeah coz it goes thru the freaking cabin. :twisted:
Hah and warms up the occupants :twisted:
Demisting the interior is just opening up the 1/4 vent windows innit?
You have to make glass temp same on both sides.
:shock: Physics has got the better of me :cry:
PostPosted: Fri Nov 26, 2004 11:28 pm
So you pull out the heater and the inside of the car is cooler but the motor will run hotter!
Just what you need on a stinking hot day! I would rather be driving along hot rather than sitting on the side of the road waiting for the motor to cool down!
PostPosted: Fri Nov 26, 2004 11:32 pm
If i put in a thermo fan... a la Dr Trim; would this keep it cool enough - enough that would balance the heat that would come from taking the heater out.
PostPosted: Sat Nov 27, 2004 4:58 am
The whole thing of the minis always overheating is a bit of a myth. As long as you have a clean decent radiator, a cold thermostat, your mixture is set right and your fan is the right way around there's no need for a thermal fan especialy in Adelaide where you're a stone throw from antarctica - am I wrong?
PostPosted: Sat Nov 27, 2004 5:07 am
Hmmm.. with a big motor the stock 3 core rad can be marginal on hot days. Yes I had a real Cooper S- watching the needle creep up to H in traffic was not funny! :cry:
Yeah I know the handbook sez turn the heater on.. :x
I run a MiniMatic fresh air heater under the hood of the 1310, but a bare heater core there takes up less room and still adds to the cooling capacity. Ask kazjim what a fifference it made when to his turbo!
PostPosted: Sat Nov 27, 2004 10:19 am
A Mate of mine has a thermo fan on his 1310 and a normal fan but no surround and he says it get very hot at the lights and when in traffic. He has a large 4 cors rad and i told him to put the rad surrond back on to allow the fan to work properly.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Sat Nov 27, 2004 2:59 pm
Its only an 1100 and it has never got to hot... stays around Normal even on days like this... 36 degrees.
oh, and the radiator is the standard one.
hmm will it really affect it that much?
PostPosted: Sat Nov 27, 2004 3:33 pm
Try it. If it gets hot stick a heater core behind the grille where the air can blow thru it. Helps a lot on hot days- more water in circulation, and more cooling area. 8)
PostPosted: Sat Nov 27, 2004 3:48 pm
So just remove the heater and the hoses coming from the heater, go straight into a heater core.
Where should i get the core from and about how much moola?
PostPosted: Sat Nov 27, 2004 4:57 pm
Its inside your heater willy - open the heater and remove all other parts but use the core behind your grille.
PostPosted: Sat Nov 27, 2004 5:42 pm
Ahh... im with ya now.
Might start it on monday when theres less heat :shock:
