It is currently Sat Jul 19, 2025 4:39 pm
 Post subject: Brake piston compression
PostPosted: Sun Feb 25, 2007 8:59 am
What does everybody use to compress the piston when doing a pad change of a bisc braked car?
 Post subject: brake
PostPosted: Sun Feb 25, 2007 9:04 am
g clamp is what i use at work
PostPosted: Sun Feb 25, 2007 9:58 am
I is a mookenik
go to repco or peps and buy a steering wheel puller they usually work well i use it. or g clamp or a 16" pair of multi grips
PostPosted: Sun Feb 25, 2007 10:43 am
I like to use a vice, not because of the brute strength, but because it's got a pair of parallel jaws and can give gentle and consistant pressure. I also use soft jaws and a block of timber to stop any marking.
edit...ops, during a pad change. I didn't read it properly....yeah, in that case multigrips.
PostPosted: Sun Feb 25, 2007 1:24 pm
I put 2 flat spanners in between rotor and piston, then lever them apart. Do ONE pad at a time. :wink:
PostPosted: Sun Feb 25, 2007 8:15 pm
i am using this tool
Rover 214 atm ....
PostPosted: Sun Feb 25, 2007 8:18 pm
Guter Tag, Klas, das wie ein feines Werkzeug aussieht. Von wo Sie es bestellten
PostPosted: Sun Feb 25, 2007 8:29 pm
Das gibts hier beim örtlichen Motorradteile Laden :wink:
over here you can get this at the local motorbike parts shop
or ebay, is around 20€
Rover 214 atm ....
PostPosted: Sun Feb 25, 2007 8:32 pm
viel Dank. Ich halte ein Auge heraus auf ebay für eins. :)
Users browsing this forum: watsupskip and 79 guests
