It is currently Sat Aug 23, 2025 11:14 pm
 Post subject: rattles underneith
PostPosted: Wed Feb 28, 2007 6:14 pm
I is a mookenik
hey all ive had this problem for a while but now its really becoming annoying, i have a rattle under the car and i got a feeling its got to do with the gear stick cause everytime it rattles i hold or push down the gear stick and it stops, it will only do it while at a certain rev...
has anyone had this problem before or does anyone know how to fix it
i thought it might have juz been loose but everything seems tight juz wondering if its something to do with the ball at the end of the stick
PostPosted: Wed Feb 28, 2007 6:16 pm
sometimes the brake pipes rattle too
Is it a remote or rod change?
PostPosted: Wed Feb 28, 2007 6:18 pm
Slow-Po
Does your gearchange resemble this?
PostPosted: Wed Feb 28, 2007 6:19 pm
I is a mookenik
what u mean but remote and rod change?
yeah but it stops when i hold down the gearstick?
PostPosted: Wed Feb 28, 2007 6:21 pm
I is a mookenik
i think so.. i cant tell from undernieth cause the assemble is all closed up i had to check from the top
PostPosted: Wed Feb 28, 2007 6:24 pm
Use the search button.
A rod change is the later type... uses two rods to connect the gear change to the gearbox. A remote change has one rod, which is contained in an alloy extension tunnel.
Rod changes use cotton reel mounts like exhausts... which can often be broken or worn.
PostPosted: Wed Feb 28, 2007 6:25 pm
This space for rent
I had exactly this problem on an old Mini 1100 with a remote change.. at something like 2,500 RPM it'd start buzzing like an insect.. only way to stop it was to hang on.
Mind you, this engine had like 25 PSI oil pressure hot running Penrite HPR50 so it was rough as guts, but there you are.
--s
PostPosted: Wed Feb 28, 2007 6:26 pm
Tiny, don't expect a lot of help from many people that have read some of the bullshit you have posted up when you started using the forum.
PostPosted: Wed Feb 28, 2007 6:27 pm
I is a mookenik
well to tell u the truth lol my mini is exactly an 1100 mini k and it starts to rattle at the same revs did u find out what it was and it looks like it could be a rod type
PostPosted: Wed Feb 28, 2007 6:30 pm
I is a mookenik
willy i dont bullshit man every i ask or say is genuine but like ive said a dozen times i dont know much about mini's im still learning about them and the mechanics of them so give me a break, im still not sure waht noises are normal and what ones aint, and one for thing if u dont like my post stop reading them and stop replying to them
PostPosted: Wed Feb 28, 2007 6:32 pm
If the linkage is all inside a long alloy box, it's a remote shift, not rodchange.
Remotes are better.. (puts on flameproof suit..) 8)
PostPosted: Wed Feb 28, 2007 6:34 pm
I is a mookenik
ah <MOD EDIT> language sorry i meant remote , i read poees reply wrong lmao
PostPosted: Wed Feb 28, 2007 6:42 pm
rod changes dont rattle, so its a remote change.
otherwise its your exhaust rattling against your gearshift or something wrong with your mounts
This space for rent
This was like 10 years ago, and I don't remember ever finding a permanent fix. I tried all sorts of stuff, but I from (my very poor) memory wrapping the ball on the end of the gear stick in gaffa tape might have been the best dodgy fix, albeit temporary.
--s
Users browsing this forum: No registered users and 146 guests
