It is currently Sun Aug 24, 2025 4:07 am
PostPosted: Wed Feb 28, 2007 6:44 pm
you can try a different weight gearknob, and or you can take the nylon bush out
PostPosted: Wed Feb 28, 2007 6:46 pm
This space for rent
Remotes are better.. (puts on flameproof suit..) 8)
OK, I'll bite :D The only remote change I had was awful, and I never managed to get it to either stop buzzing, or feel particularly accurate. I've had a couple of rod changers since and they've been far, far nicer..
Then again, I reckon Morris should have stuck with the gearchange on the 850. No linkages, just straight into the 'box ;)
--s
PostPosted: Wed Feb 28, 2007 7:05 pm
tinymorris1969 wrote:
well to tell u the truth lol my mini is exactly an 1100 mini k
I thought it was an 1100Sports? 8)
From the engine number that you posted in another thread it has a later motor so it may have a remote or it may have a rod-change.
With a rod-change you are supposed to lift the stick for reverse.
With a remote you have to give the stick a knock to go past the detent into reverse. (it will give a little knock or click when you move the stick past the 3/4 position)
A rod change will also have an oil leak under the engine.
PostPosted: Wed Feb 28, 2007 7:07 pm
:lol: :lol:
PostPosted: Wed Feb 28, 2007 8:07 pm
--s
Currently we're running 2 remotes, on a mild 1293 and a hot 1360. Not sloppy, and no buzzes in either.
I find the secret is to eliminate wear in the linkage. A major cause is worn shift bushes in the diff housing, they are sloppy on the shaft when new. Like Keith Calver, I make my own bushes.
Another wear point is the shift balls on the bellcrank in the diff housing- I built them up with nickel rod and polished them back to size. :wink:
Back at the gearlever, the nylon bush on top wears out, so can the one at bottom of lever.
PostPosted: Wed Feb 28, 2007 8:18 pm
I gotta secret. It was provided out of thin air and it works a treat. A few other people have used it as well. But it is ONLY for the remote change boxes.
It should be a how-to because of the pleasure it brings. The mini is so quiet, I an here the hand brake actuators in the rear brakes rattling on the backplates!
Here's the part.
http://morrisminorspares.co.uk/shop/pro ... c601c2d6ef
and here's the link that explained it.
http://www.ausmini.com/forums/viewtopic ... t=trunnion
PostPosted: Wed Feb 28, 2007 8:25 pm
This space for rent
I almost read that as "Like Calvin Klein, I make my own undies" :lol:
Every word in that sentence is familiar, but I have no idea what you just said. ;) It was a long time ago, but I just wrapped mine in tape. I think your method is probably better.. :lol: :lol: :lol:
PostPosted: Thu Mar 01, 2007 4:10 pm
I is a mookenik
hmm thanks mick ill give it a try, do you know if you can get them in sydney or australia cause thats sites a english one
PostPosted: Thu Mar 01, 2007 4:52 pm
Yeah, they are a morris minor part, so Morris minor spare places should have them. Apparently, asking for a suspension trunnion bush is easily understood by the Moggie drivers. It's a bit like asking for a rubber uni from a mini specialist, everyone knows what you're talking about..
