It is currently Tue Aug 19, 2025 6:20 am
PostPosted: Thu Mar 01, 2007 5:01 pm
I am after one of the carpeted boot board kits from my mini clubman, can anyone tell me where I can buy one?
Ian - My Ve SSV Ute - Looking for a Mini
PostPosted: Thu Mar 01, 2007 5:03 pm
There's a guy selling them on the UK eBayhttp://cgi.ebay.co.uk/Boot-Liner-Lining-Kit-for-the-Classic-Mini_W0QQitemZ140088441525QQihZ004QQcategoryZ43122QQrdZ1QQcmdZViewItem
David L
PostPosted: Thu Mar 01, 2007 5:43 pm
Anyone in Aussie?
PostPosted: Thu Mar 01, 2007 5:44 pm
I was going to make them, but I am lazy.
They are a piece of piss.
Trim them in a light-ish material to make it a bit more 'modern'
PostPosted: Thu Mar 01, 2007 6:59 pm
As much as I hate to agree with young Willster :shock: just grab the plans and build one yourself...then you know it will be done right :D
PostPosted: Thu Mar 01, 2007 7:12 pm
plans??? where??? and what materials?
 Post subject: Boot Board
PostPosted: Thu Mar 01, 2007 7:21 pm
Have a go at making one they are really simple, it only take's a few hours.
Steve
Classic Not Plastic
PostPosted: Thu Mar 01, 2007 7:27 pm
That's what Im saying I will do... jsut to semi-hijack the thread.
But plans would be nice .... otherwise what materials would be best suited for this project?
PostPosted: Thu Mar 01, 2007 7:59 pm
I made mine from scratch to suit amps etc. but this link may help u..
http://www.minifinity.com/modules.php?op=modload&name=TechLibrary&file=doku&id=boot_board_dimensions
 Post subject: Boot Kit
PostPosted: Thu Mar 01, 2007 8:01 pm
When i made mine i used MDF. At the front of the tank i used 3mm. and all of the other pieces including the two side's and the back board, behind the rear seat also the bottom of the boot ontop of the spare wheel i used 6mm. I bought the carpet from clark rubber, and i used kwik glue I think thats how you spell it, from bunnings.
Steve
Classic Not Plastic
 Post subject: Boot board
PostPosted: Thu Mar 01, 2007 9:15 pm
Hey,
We make these, i have one almost exact to the 'S' type in my mini K with single tank.
We make them sit on top of the spare (for single tank mini's).
The corner that the 'S' twin tank sits on is covered.
I am sure we could the carpeted instead of 'S' trim
Andrew..
PM me for a price.....ill try not to shock. :D
Andrew@Minisport, South Australia
Ph: 08-8177-1275
Skype: minisport.au
www.minisport.com.au
Minisport for all your mini parts
 Post subject: Re: Boot Kit
PostPosted: Fri Mar 02, 2007 7:08 am
Steve
kwik glue?? that's that contact adhesive?
cheers on the info mate I'll check it out. I'm just getting idea's for this year's projects. As we all know there's always something you can do to or for your beloved Mini.
PostPosted: Fri Mar 02, 2007 9:09 am
When I made mine I got a bit too keen with the staple gun and forgot to use the contact adhesive!
It's not bad though, I kept it pretty tight with the stapling and unless you look for it you'd never know.
Here's what mine look like (used minifinity plans, 3mm (tank), 6mm (back & sides) & 9mm (base) MDF & car carpet from Bunnings)
Since I took these pics I also made up some carpeted cards to fit into the recessed bits on the inside of the boot lid just to finish it off.
PostPosted: Fri Mar 02, 2007 10:10 am
Looks great!!!
thanks for the pics got a idea now what it should roughly look like cheers
PostPosted: Fri Mar 02, 2007 10:15 am
As a slightly different idea I saw this following a link from mz.mini's post in the members gallery , http://www.aafabrications.com/bodykit.htm , they do some interesting other bits and pieces for mini's too .
Users browsing this forum: Majestic-12 [Bot] and 93 guests
