It is currently Sun Aug 03, 2025 6:31 am
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2, 3  Next
PostPosted: Wed Mar 07, 2007 4:08 pm
Hey all,
where can i get a waterproof fitted mini car cover from?? i saw them on ebay a while back on i think minisport1275's online store, but not 100% on it. Does anyone have a waterproof fitted mini car cover that they have on their mini??? would like to know if they are any good? im sick of the rain sprayin my car through the sides of the carport when the car is nice n dry n clean!!
cheers any help will be much appreciated.
>Rude<
1992 Toyota Starlet GT EP82
PostPosted: Wed Mar 07, 2007 4:54 pm
Slow-Po
These are great.
http://www.covercraft-pacific.com/online/default.asp
The covers are custom made to suit your car in the USA to the material of your choice so allow a couple of months. The are made from different fabrics - using a fabric lets the car "breathe" in order to let it dry out if wet unlike the plastic super cheap covers.
8)
PostPosted: Wed Mar 07, 2007 5:19 pm
Try here too they are Aussie made: www.amdaat.com.au/~ccc25/
PostPosted: Wed Mar 07, 2007 8:21 pm
Die Die Die!!
now lets not dig out the link for the Bubble air filled car cover .. those were rediculous..
PostPosted: Wed Mar 07, 2007 9:14 pm
Im so tempted to buy one of these! It would b excellent, polish the car at the start of the year, drive it at the end of the year, and its still perfectly clean!! $1090 to suit a mini. Just what i need! http://www.carcoon.com.au/index.html
PostPosted: Wed Mar 07, 2007 9:39 pm
Be carefull with a waterproof cover, they sound like a great idea, but they have been known to trap water in. I.E they need to come off frequently to ensure their's no trapped moisture causing rust
and a few conversions:
13B Extend in a 1600
PostPosted: Wed Mar 07, 2007 9:55 pm
I got the maximum outside protection one from minisport. It lasted about two months before cracking up in the sun. They kindly replaced it but the company in the UK that they come from said maybe the conditions are worse here! Now I have a cover to keep the cover out of the sun, not very practical. I will have a look at the other suggestions above too.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Wed Mar 07, 2007 10:36 pm
i will need one for when the mini is painted and sittying in teh shed, but not for a few months dont want it to stick to anything
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Thu Mar 08, 2007 8:40 am
Slow-Po
Correct. The one I have is made from a goretex like material that's produced by 3M, I've had it for over a year and it's stood up to the elements very well. 8)
PostPosted: Thu Mar 08, 2007 9:01 am
that carcoon one is awesome!!! but its a lil over the top for what i need it for, its not like i have a showcar like u hanra :wink:
Flute, how much was the maximum outside protection one from minisport?? is it waterproof and breathes???? ie air flows inside still. wat was the price for it??? i cant remember
Speedy, is that 3M one suited for minis, like does it have a tight fit?? where did you get it from and $$$$?
>Rude<
PostPosted: Thu Mar 08, 2007 9:35 am
Slow-Po
Perfect fit for roundnose, with the elastic edges going over the bottom of the bumper bars. Cost depends on the material you choose (the top of the range stuff that they use on the Ford Perfomance Racing cars was around $400), to order one you call the guys directly on the website.
PostPosted: Thu Mar 08, 2007 9:50 am
Resident Test Pilot
I have one that works perfectly. Keeps all the elements away from the mini. Doesn't trap water inside. Takes no time at all to cover the car with it. In fact its as easy as pushing a button and driving in and pushing the button again.
It even has a bar fridge in it....hmmmm beer!
PostPosted: Thu Mar 08, 2007 3:03 pm
it might be better to tie a tarp on the carport posts as a
wall that way there is nothing touching your car and rubbing
the paint work
Barney's owner Cooper s
Jerry's owner Clubby Van
PostPosted: Thu Mar 08, 2007 9:35 pm
I think it was $240 or so, they have them on ebay, there are a few levels to choose from, they do breath. They are a better shape for a roundie than a clubby though. It was good until the sun got to it and in a few months it was useless. It was designed for outside use so it was dissapointing.
Member: VMCI #2474
PostPosted: Fri Mar 09, 2007 8:13 am
i thought it was around $200+ a lil pricey i think but ill keep looking around.
ive already got one side of the carport covered from post to post (the sun used to come in on that side all morning, and the rain of course too).....but the problem is with one of the sides of the car port is the house (only two posts on the whole carport which has the covering on it already) and so its difficult to cover the side that i want to. any ideas?
ill get a pic of it if it will help?
>Rude<
Users browsing this forum: timmy201 and 82 guests
