It is currently Sun Aug 17, 2025 11:35 am
 Post subject: coil
PostPosted: Wed Mar 28, 2007 4:34 am
hi guys i have a 75 cubman s the coil keeps going just before it gose it get really hot would someone be able to help me out thanks guys
PostPosted: Wed Mar 28, 2007 6:28 am
bring it to our workshop at sunnybank
well help you out
and ill gladly take some pics of your mini while it there :)
give us a call 33451386
A.C.E.S
'94 Honda EG4 Civic. -Daily-
'95 Honda DC2 Integra
PostPosted: Wed Mar 28, 2007 6:55 am
Sounds like an internal short in the windings of the coil. Time to replace.
PostPosted: Wed Mar 28, 2007 6:59 am
My bet is it's a `resistor' coil running on 12V without one- Gafmo had this same problem. They get hot then die in the arse... Ok when cool again :wink:
This burns your points out quick, too.
PostPosted: Wed Mar 28, 2007 6:00 pm
my dont have a resistor but i will try a new coil and see how that gose thanks guys
PostPosted: Wed Mar 28, 2007 6:58 pm
Thats the problem ...with the coil you are using you may need a Resistor in line. Any codes on the coil :?:
PostPosted: Wed Mar 28, 2007 7:14 pm
Most Oz Minis had a 12V coil with no resistor.
Look on bottom, if it says 12V it's right. If it says `use with resistor' either go buy a ballast resistor from Supercrap etc, or get a 12V marked coil. :wink:
PostPosted: Wed Mar 28, 2007 7:20 pm
I removed that post because it would probably burn out rather than just get hot, and it would also probably not start because the transformer ratio was buggerd up...soz for the confusion, you quoted faster than I could rethink!
Users browsing this forum: No registered users and 395 guests
