It is currently Wed Aug 06, 2025 6:45 am
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2, 3  Next
PostPosted: Wed Apr 25, 2007 12:45 pm
Hi all,
Is it possible to get stronger gearboxes for a worked 1100cc engine?? or stronger gears etc to fit in the existing one??
dont want to have to pull my engine n gearbox out yet again in a year to rebuild the gearbox once again!
>Rude<
1992 Toyota Starlet GT EP82
PostPosted: Wed Apr 25, 2007 12:49 pm
Kazjim was running a standard box on a Turbo 998.
He never broke anything.
Should be fine if you are kind to it.
No more Minis!......For now.
PostPosted: Wed Apr 25, 2007 1:01 pm
its a daily driver too any it does alot of km's everyday, approx 40-50kms a day. would wear and tear do this?? its got a heavy duty clutch in it and i treat the gearbox very well, never crunch gears either.
PostPosted: Wed Apr 25, 2007 1:05 pm
Mine does about 500km a week and has not had a problem in 5 years running, so I think there may have been something wrong with your box to start with.
Cheers Pete
PostPosted: Wed Apr 25, 2007 2:16 pm
would this be a good alternative if my gearbox has died??
http://cgi.ebay.com.au/Mini-Cooper-S-MkII-4-Speed-All-Synchromesh-Gearbox_W0QQitemZ120110509812QQihZ002QQcategoryZ32072QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
and will this fit in my mkI morris mini deluxe 1100cc engine??
id rather put a strong cooper s gearbox in if my gearbox has too much damage.
help would be much appreciated :)
>Rude<
ps is this anyones gearbox on ausmini??
PostPosted: Wed Apr 25, 2007 2:29 pm
I is a mookenik
dude tiny does exactly 60kms a day during the week plus extra driving duringthe weekend and the only issue i have is i have to double clutch 2nd gear or it will grind and thats cause the synchro was never fixed when the engine and gearbox was rebuilt before i bought him, juz gotta be gentle
PostPosted: Wed Apr 25, 2007 2:31 pm
I is a mookenik
is there any real big difference in the strength between the gearboxs?
PostPosted: Wed Apr 25, 2007 2:37 pm
thats wat im askin! :lol:
well obviously a 1275 cooper s engine has more ponies than a worked 1100cc engine so the gearbox would be stronger in the cooper s wouldnt it?? i dont kno much about gearboxes sorry...im learning
PostPosted: Wed Apr 25, 2007 2:40 pm
I is a mookenik
i dont think they would of been, gearboxes are made of the same sorter material and but like i said im not sure on minis
PostPosted: Wed Apr 25, 2007 2:42 pm
wheres the doc when you need him :wink:
PostPosted: Wed Apr 25, 2007 3:51 pm
Basically the same gearbox for Cooper S 1275s and normal Mini 1100s. Same casing and most gears (just different ratios).
Don't buy that gearbox on Ebay far too dear, it's probably worth $150 max in my opinion. Get your gearbox rebuilt properly. Very expensive but most Mini stuff is.
PostPosted: Wed Apr 25, 2007 5:20 pm
What TK said ^^^.
The only difference between Mk2 S gears, and Mini-K gears, and A series rodchange gears, is the Cooper S has 1 more tooth on the 1st motion shaft, and the cluster gear had it's `big gear' teeth cut to suit (p/no 22G1040).
No, the S ones are no stronger. Just 1st, 2nd and 3rd are a little higher geared- so less rev drop to 4th. :wink:
 Post subject: S/C
PostPosted: Wed Apr 25, 2007 5:44 pm
and straight-cuts are noisier :!:
PostPosted: Wed Apr 25, 2007 5:46 pm
ive got straight cut gears in mine, does that change the strength of the gears?
PostPosted: Wed Apr 25, 2007 5:52 pm
I is a mookenik
straight cuts are stronger
Users browsing this forum: Bing [Bot] and 71 guests
