It is currently Tue Jul 29, 2025 7:56 am
 Post subject: Fan Belt
PostPosted: Thu Apr 26, 2007 10:10 pm
Is there any easy way to change the fan belt on a mini?
Thanks.
PostPosted: Thu Apr 26, 2007 10:13 pm
Nope.....
 Post subject: No
PostPosted: Thu Apr 26, 2007 10:14 pm
No...you can try and feed it around the fan blades one by one until you get the whole belt around back....but it ain't easy!!
PostPosted: Thu Apr 26, 2007 10:17 pm
Expect to lose some skin off your knuckles.
sorry for the happy news..... :wink:
PostPosted: Thu Apr 26, 2007 10:19 pm
My order of business;
- loosen the alternator and move forward
- remove fan
- remove water pump pulley
- put on belt
- put two bolts in water pump pulley to keep it lined up
- reposition and tighten alternator
- remove bolts form waterpump pulley
- install fan and pulley
PostPosted: Thu Apr 26, 2007 10:25 pm
U forgot to mention removal of the old belt...Otherwise, follow that procedure and u will be right... Its not a simple as a belt on a Dinosaur Buick V6..
PostPosted: Thu Apr 26, 2007 10:27 pm
I had assumed it had busted and was lying beside some inconveniently remote road.
PostPosted: Thu Apr 26, 2007 10:33 pm
- remove fan
- put on belt
Um- why do you need to remove the water pump pulley...?? never seen the need on an Oz Mini or Moke..
PostPosted: Thu Apr 26, 2007 10:37 pm
I put the belt on the pulley and reattach the pulley rather than stretching the belt. It means I dont need to loosen the alternator much and that I can do the job one handed (a requirement of mine :wink: )
PostPosted: Thu Apr 26, 2007 10:42 pm
Ummmm But you want to stretch the belt ever so slightly....new ones stretch a little anyway and may need re-tightening....its something I have always checked :idea:
PostPosted: Thu Apr 26, 2007 10:47 pm
my problem is that my busted hands cant physically stretch the belt over- so that is my alternative - I take the slack out with the alternator.
PostPosted: Thu Apr 26, 2007 10:57 pm
It's getting the fan bolts off that has me crying like an 8 year old girl.
PostPosted: Thu Apr 26, 2007 11:04 pm
You mean its not an easy task ????
haha
twenty minutes to have the hanging from the end of a hydraulic hoist above the car - undo the top radiator bracket and pull the radiator forward after removing the top radiator house. Loosen alternator - slip the new belt over the fan blades then over the alternator pulley. Adjust tension, refit top radiator hose and radiator bracket. Refit engine - easy peasy
PostPosted: Thu Apr 26, 2007 11:06 pm
Now having said the above removal of engine was the way to go - its not !!!!!
But the fan belt is a terrible job as each above has testified.
PostPosted: Thu Apr 26, 2007 11:13 pm
yeah fit it around the fan blades one by one, use the indent in the radiator shroud put there for this purpose
Users browsing this forum: Bing [Bot], goodie and 72 guests
